  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
Search
Milling Chucks, Collets & Kits
Drill Chucks
Pull Studs
Mill Toolholding Kits
Vises
Mill Vise Jaws
Workholding Accessories
Milling
Indexable Milling Kits
Complete Indexable End Mill Kits
Cut-Off Tooling
Grooving Tools
Small ID Grooving & Threading Tools
Threading Toolholders
ID Toolholders
OD Toolholders
Haas Notch Groove and Thread Inserts
Haas Notch Groove and Thread Toolholders
Broaching Toolholders
TL & CL Toolholding
BOT Toolholding
BMT Toolholding
Live Toolholding
Reduction Sleeves
Spindle Liners
Lathe Collet Chucks
5C Collets Kits
ER Collets
Tap Collets
ER Collet Kits & Accessories
Straight Shank Keyless Drill Chucks
Tool Management
Spindle Taper Cleaner
CNC Clearing Fans
Toolholding Kits
WIPS Replacement Stylus
7-Piece Measuring Kit
Clamp Force Gauge
HPC-300
HPC-1000
TSC-300
TSC-1000
Doors
Mill Coolant
Mill Productivity Options
Hydraulic Power Unit
Indexers
Rotary Tables
BROACHING INSERTS
HAAS TESTED. HAAS PROVEN.
Haas Broaching Inserts
The Haas Broaching line consists of a wide range of tools and inserts to form a variety of shapes in many sizes. Select the application required – such as keyway, hex, or square – and filter through the range of insert sizes to find the one to suite your needs
Haas broaching inserts are manufactured from a sintered alloy, and then heat treated to a hardness of 70-71Rc. This gives the inserts high toughness, and allows them to withstand the high pressures generated during the broaching process. The inserts receive a titanium nitride (TiN) coating to increase wear resistance and reduce friction.
Haas keyway inserts are available in standard inch from 3/32” to 5/8” wide and metric standard sizes from 2mm to 16mm wide. There are also up to four tolerance options, depending on the type of fit that is required. See the broach insert technical details page for the type of fits available.
Keyway inserts that are identified with the –SM code will form a small chamfer (0.2mm x 45°) on the intersection point between the hole and the walls of the broached slot, leaving the hole burr free. Refer to the technical specs of the inserts to verify that the keyway depth and chamfer dimension suit your needs.
Form internal squares or hexagonal shapes by selecting the size and range desired. The technical detail page will also display the recommended pre-hole diameters required before forming each shape.
VIDEOS
Alignment plates are available for all of the toolholders, to accurately orient the holder to the workpiece on milling centers. Aligning the holders on lathes without Y-axis capability is easily performed using eccentric bushings to finely adjust the holder to workpiece centerline.
  1. Haas Tooling
  2. Lathe Tooling
  3. Broaching Inserts
Category
Price: Low To High Price: High To Low Part Number: Low To High Part Number: High To Low
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
