  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Automation HTEC Network Industry 4.0 Haas Certification
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Part #
      Mill Toolholding Milling Holemaking Threading Lathe Tooling Tooling Accessories Mill Workholding Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Grooving Tools
Part #
BUY TOOLS DIRECT FROM HAAS, OR ADD THEM TO YOUR NEW MACHINE PURCHASE THROUGH YOUR LOCAL HAAS FACTORY OUTLET
* Orders are currently shipping to United States addresses only
  1. Haas Tooling
  2. Lathe Tooling
  3. Grooving Tools
Grooving Tools
Haas multi-functional grooving tools can be used for machining grooves, parting-off, and facing, as well as general turning operations.
These versatile tools use allow the machinist to use a single tool for many applications, reducing the number of tools in the turret, and the number of necessary tool changes. The carbide inserts are reversible, with two cutting edges for more economical machining. The flat geometry of the cutting edge and wiper function of the insert ensure excellent surface finishes, even at high feedrates.
Advantages
  • Suitable for grooving, facing, face grooving, parting-off, and general turning
  • Strong clamping system ensures stable and accurate machining
  • A single tool can be used for multiple applications
  • Replaceable carbide inserts for economical machining
  • Available for OD and ID applications
How to Select the Right Grooving Tool Kit
The Haas Tooling Grooving Kits are defined by the following requirements:
  • Size of the tooling used by the lathe turret
  • External or internal machining
  • Required cutting depth (T-Max)
  • Cutting width of the insert
Use the filters to select the parameters that correspond to your grooving application.
Block Shank Height for Haas Turning Centers
Category
FIND DISTRIBUTOR
  • Rotary Fit Chart
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
