  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Lathe Turret Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
Search
Drill Chucks
Pull Studs
Mill Toolholding Kits
Vises
Mill Vise Jaws
Workholding Accessories
Milling
Indexable Milling Kits
Complete Indexable End Mill Kits
Burrs
Cut-Off Tooling
Grooving Tools
Small ID Grooving & Threading Tools
Threading Toolholders
ID Toolholders
OD Toolholders
Haas Notch Groove and Thread Inserts
Haas Notch Groove and Thread Toolholders
Broaching Toolholders
TL & CL Toolholding
BOT Toolholding
BMT Toolholding
Live Toolholding
Reduction Sleeves
VDI Toolholding
Spindle Liners
Lathe Collet Chucks
5C Collets Kits
ER Collets
Tap Collets
Straight Shank Keyless Drill Chucks
Tool Management
Spindle Taper Cleaner
CNC Clearing Fans
Storage & Handling
3D Sensor Kit, Inch, CT40
3D Sensor Kit, Metric, SK40/DIN
3D Sensor Kit, Metric, BT40
3D Sensor Kit, Inch, HSK63A
3D Sensor Kit, Metric, HSK63A
WIPS Stylus, 3-Pack
WIPS Replacement Stylus
Spindle Test Bar
7-Piece Measuring Kit
Coolant Refractometer
Clamp Force Gauge
3D Sensor, Inch
3D Sensor, Metric
  1. Haas Tooling
  2. Measuring & Inspection
  3. Coolant Refractometer
Never Run Out of the Tools and Inserts You Need – Subscribe Today
Never experience the frustration of starting a job and finding out that you do not have all the right tools. Use our new subscription feature to automatically reorder the tools and inserts you use most often, on a schedule of your choosing – so you are always ready to run.
To set up your order as a weekly or monthly subscription, proceed through the checkout process, and select Schedule Subscription before selecting Place Order. All items in your cart must be eligible for subscription, in order to schedule a reorder.
Coolant Refractometer, Brix 0-32%
Part #: 09-0032
COOLANT REFRACTOMETER
Price: 24.95
Each pack contains s not sold individually.
Not Currently Available
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
Haas Coolant Refractometer
MAINTAINING PROPER COOLANT CONCENTRATION IS CRITICAL TO MAINTAINING A STABLE MACHINING PROCESS.
The Haas coolant refractometer is a simple, easy-to-use, handheld device for determining the concentration of water-soluble machine tool coolant. Simply place a few drops of coolant on the refractometer’s prism, and secure the cover plate. Then, point the prism at a light source, focus the eyepiece, and read the scale. The clear color separation on the scale indicates the concentration level of the coolant.
The Haas refractometer measures on the Brix scale (0-32%), rather than measuring the actual concentration of the coolant. To determine the actual concentration, multiply the refractometer reading by the coolant’s refractive index. This can vary by coolant brand and type, so be sure to refer to the coolant’s product data sheet.
A coolant concentration that is too high (rich) not only wastes coolant concentrate, but also leaves a sticky, oily residue on parts, cutting tools, and inside the machine. A coolant concentration that is too low (lean) can reduce your tool life, cause corrosion on your parts and inside the machine, and may lead to bacterial growth in your coolant tank.
Automatic temperature correction (ATC). Because refraction readings are affected by temperature changes, many refractometers must be calibrated before every use. The Haas coolant refractometer features automatic temperature correction (ATC), which automatically adjusts for temperature changes, eliminating the need for constant calibration. For initial calibration (or to verify calibration at any time), make sure the prism is clean, and place a few drops of distilled or tap water on the lens. When correctly calibrated, the separation line will be on zero. If it is not, turn the adjustment screw to align the separation line until it is at zero.
FEATURES AND BENEFITS:
  • 0-32% Brix scale
  • Automatic temperature correction (ATC)
  • Adjustable eyepiece with rubber eyecup
  • Sturdy padded case to protect and store the refractometer
  • Includes screwdriver for calibration, and dropper for coolant collection
Plant(s) for Ecom Sale 1000 (HAI) 2000 (HAE)
System of Measurement Brix
Range 0-32%
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
09-0032
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
