  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
  • Service
  • Videos
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
    • Mill Toolholding Shop All
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
    • Mill Workholding Shop All
      • Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling Shop All
      • Indexable Milling Kits
      • Complete Indexable End Mill Kits
      • Burrs
    • Lathe Tooling Shop All
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • Broaching Toolholders
    • Lathe Toolholding Shop All
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
    • Lathe Workholding Shop All
      • Spindle Liners
      • Lathe Collet Chucks
    • ER Collets & Chucks Shop All
      • ER Collets
      • Tap Collets
      • Straight Shank Keyless Drill Chucks
    • Holemaking Shop All
    • Threading Shop All
    • Tool Management Shop All
    • Tooling Accessories Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
    • Package Kits Shop All
    • Apparel & Accessories Shop All
    • Storage & Handling Shop All
    • Measuring & Inspection Shop All
      • 7-Piece Measuring Kit
      • 3D Sensor Kit, Inch, CT40
      • 3D Sensor Kit, Metric, SK40/DIN
      • 3D Sensor Kit, Metric, BT40
      • 3D Sensor Kit, Inch, HSK63A
      • 3D Sensor Kit, Metric, HSK63A
      • 3D Sensor, Inch
      • 3D Sensor, Metric
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
    • Automatic Pallet Changer Shop All
    • Lathe Turret Shop All
    • Tool Changer Shop All
    • Chip Management Shop All
    • Coolant Shop All
    • Counterbalance Shop All
    • Electrical Cabinet Shop All
    • Enclosure Shop All
    • Hydraulics Shop All
    • Lubrication Shop All
    • Maintenance Shop All
    • Pendant Shop All
    • Probing Shop All
    • Rotary Shop All
    • Spindles Shop All
    • Tailstock Shop All
My Cart
Find A Dealer
Search
Drill Chucks
Pull Studs
Vises
Mill Vise Jaws
Milling
Burrs
Cut-Off Tooling
Grooving Tools
ID Toolholders
OD Toolholders
TL & CL Toolholding
BOT Toolholding
BMT Toolholding
Live Toolholding
Reduction Sleeves
VDI Toolholding
Spindle Liners
Lathe Collet Chucks
ER Collets
Tap Collets
Tool Management
CNC Clearing Fans
Storage & Handling
3D Sensor, Inch
3D Sensor, Metric
WIPS Stylus, 3-Pack
Spindle Test Bar
Clamp Force Gauge
  1. Haas Tooling
  2. Measuring & Inspection
  3. 3D Sensor, Inch
Never Run Out of the Tools and Inserts You Need – Subscribe Today
Never experience the frustration of starting a job and finding out that you do not have all the right tools. Use our new subscription feature to automatically reorder the tools and inserts you use most often, on a schedule of your choosing – so you are always ready to run.
To set up your order as a weekly or monthly subscription, proceed through the checkout process, and select Schedule Subscription before selecting Place Order. All items in your cart must be eligible for subscription, in order to schedule a reorder.
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
Haas Universal Inch 3D Sensor, 3/4" Shank x 0.2" Point Diameter, by Haimer
Part #: 09-0034
3D SENSOR, INCH
Price: 374.95
Each pack contains s not sold individually.
Not Currently Available
Weight 3.5 lbs \ 1.6 kg
Country of Origin Germany
[OAL] Overall Length 2.55 in
[OAH] Overall Height 6.37 in
[OAW] Overall Width 2.6 in
[Ød₂] Diameter 0.5 in
[L2] Length 1.97 in
[LH] Head Length 1.25 in
[⌀DMM] Shank Diameter 0.75 in
Accuracy 0.0004”
09-0034
Haas Universal 3D Sensor, by Haimer
Meet your new favorite tool! It doesn’t just do the job of an indicator and an edge finder – it does the job better.
Finding edges, corners, and hole centers has never been easier than with the Haas Universal 3D Sensor, by Haimer. This 3-dimensional edge finder allows you to locate and tram-in surfaces quickly, easily, and more accurately – on the first attempt. No more touch-and-feel with a piece of paper or a spinning edge finder. No more adding or subtracting half the diameter of the probe tip. Simply zero the sensor on the part and then zero the machine. Zero on the sensor = zero on the part! And, because you don’t have to run the spindle, like you do with a traditional edge-finder, you can use the Haas Universal 3D Sensor with the machine doors open.
And don’t worry about over-traveling while touching off. The sensor has a large travel range, and the ceramic probe tip is designed to fracture if over-traveled, to avoid damaging the sensor itself. Simply unscrew and replace the broken probe tip and you’re back on the job. No tools necessary.
        Features:
  • Clamps into mill spindle
  • Measures in 3 axes
  • Replaceable sensor probes, without tools
  • Large overrun distance and preset breaking points
  • Radial runout compensation
  • IP67 waterproof
    Applications:
  • 3-dimensional edge finder locates in X, Y, and Z axis
  • Locate edges of workpieces and fixtures
  • Measure surface flatness
  • Measure workpiece dimensions
  • Accurately locate centers of holes and shafts
  • Use with machine doors open
REPLACEABLE SENSOR PROBE
MEASURES IN X, Y, AND Z AXES
ZERO ON SENSOR = ZERO ON PART
MOUNTS IN END MILL HOLDER
LOCATE CENTERS OF HOLES
TRAM-IN WORKHOLDING
USE WITH DOORS OPEN
ALWAYS READY TO GO
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
09-0034
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
