END MILL HOLDERS
HAAS TESTED. HAAS PROVEN.
  2. Mill Workholding
  3. Vise Kits
HAAS MAKES WORKHOLDING EASIER
COMPLETE INDUSTRY-TESTED MILL WORKHOLDING KITS, AT AFFORDABLE PRICES!
______________________________________________________________________________
Our pre-configured Vise Kits are your complete workholding solution. All our kits comes with everything you need to start using them immediately.
      Single-Station, Fixed-Jaw
Haas fixed-jaw vises are a single-station design, with one stationary jaw and one moveable jaw. These manual milling vises provide secure workpiece clamping and accurate positioning for all machining operations. The simple bolt-on jaws are easily changed or reversed, without disassembling the vise, and the jaws can be attached to the outside ends of the jaw plates to accommodate larger workpieces. Replacement hard jaws, as well as machinable steel and aluminum soft jaws are available.
Each vise includes a vise handle, and all necessary mounting hardware: toe clamps, mounting bolts with flange nuts and T-slot nuts, and alignment keys.
  • Extra-wide opening
  • One-piece ductile iron body, HRC 45
  • Precision-ground sides allow side mounting (except flange-style)
  • Angle-lock system reduces jaw lift
  • Fixed height simplifies multi-vise setups
Self-Centering
Haas self-centering vises feature compact, low-profile designs that automatically adjust the workpiece to the center of the vise for increased precision and repeatability. The simple bolt-on or drop-in jaws (depending on model) are easily changed or reversed, and feature a 45° dovetail and serrated gripping surfaces. The serrated teeth provide maximum grip on non-hardened materials, while the dovetail provides maximum clamping force for hardened materials, while providing access to five sides of the part. Replacement jaws and inserts are available, including machinable steel and aluminum soft jaws.
  • Compact design
  • Hardened-steel jaws or inserts, with a 45° dovetail and serrations
  • Tool steel construction
  • Replacement hard and soft jaws and inserts available
  • High-accuracy repeatability
* Haas by Kurt and Haas by Jergens vises currently do not include mounting hardware.
Workholding VIDEOS
ADDING WORKHOLDING TO YOUR CNC
THE OLD WAY
  • Search through large, complex catalogs for the workholding you need, or at least think you need . . .
  • Order the workholding from one source, sometimes a tooling house, sometimes the manufacturer.
  • Find the necessary adapters for your machine and the workholding, and order them from another source, unless you get lucky and the tooling house has both the workholding and the adapters.
  • Wait for parts to arrive from several vendors on different delivery schedules.
  • Assemble everything, and hope it all works.
THE HAAS WAY
  • Go to HaasTooling.com
  • Find your workholding (PRO TIP: Select a complete workholding kit from Haas that includes everything you need, at the best price around, and place a single order).
  • Everything is delivered to your door, with all the necessary information and support (including videos!) available at HaasTooling.com.
HAAS MAKES
WORKHOLDING EASY
