DT-1-I
CNC Drill/Tap Center with 20" x 16" x 15.5" travels
  • 30 Taper
  • 3 Axis
  • 10k RPM
  • 20+1 Tool Capacity
The DT-1-I is the economy version of our best-selling DT-1 Drill/Tap Center. It has the same lean-style footprint, 10,000-rpm BT30 taper inline direct-drive spindle, and 20-pocket tool changer as the standard DT-1, but with reduced axis speeds and slower tool change times.
A high-performance package is available that boosts rapids to 2400 ipm, and provides faster tool changes to shorten cycle times and reduce non-cutting time.
  • Available exclusively in India
  • Powerful BT30 taper inline direct-drive spindle
  • 1880 ipm rapids
  • 2.4 second chip-to-chip times
  • High-Speed Machining control option
  • Made in the USA
Standard Features
  • 10,000-rpm Spindle
  • 20+1 Side-Mount
  • 55-Gallon Coolant Tank
  • Media Display M-Code; M130
  • Ethernet Interface
  • Rigid Tapping
  • Coordinate Rotation and Scaling
  • Internal High-Voltage Isolated Transformer
  • Convenience Package
Shipping
  • Export Packaging
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Travels S.A.E METRIC
X Axis 20.0 in 508 mm
Y Axis 16.0 in 406 mm
Z Axis 15.5 in 394 mm
Spindle Nose to Table (~ max) 21.5 in 546 mm
Spindle Nose to Table (~ min) 6.0 in 152 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 10000 rpm 10000 rpm
Max Torque 46 ft-lbf @ 1700 rpm 62 Nm @ 1700 rpm
Taper BT30 BT30
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Cooled Air Cooled
Table S.A.E METRIC
Length 26.0 in 660 mm
Width 15.0 in 381 mm
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 4.92 in 125 mm
Number of Std T-Slots 3 3
Max Weight on Table (evenly distributed) 250 lb 113 kg
Feedrates S.A.E METRIC
Max Cutting 1200 ipm 30.5 m/min
Rapids on X 1880 ipm 48.0 m/min
Rapids on Y 1880 ipm 48.0 m/min
Rapids on Z 1880 ipm 48.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2550 lbf 11343 N
Max Thrust Y 2550 lbf 11343 N
Max Thrust Z 4200 lbf 18683 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 20+1 20+1
Max Tool Diameter (full) 2.0 in 51 mm
Max Tool Length (from gage line) 7 in 178 mm
Chip-to-Chip (avg) 2.4 s 2.4 s
Tapping S.A.E METRIC
Max Tapping Speed 5000 rpm 5000 rpm
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 102 in x 72 in x 101 in 259 cm x 183 cm x 257 cm
Export Pallet 102 in x 72 in x 101 in 259 cm x 183 cm x 257 cm
Weight 6000 lb 2730.0 kg
Talk to Us
Power & Selection – Haas-Built, High-Speed Spindles
10,000-rpm
  • Standard spindle
  • Inline direct-drive
  • Great overall performance & value
  • Good performance for 3D profiling
12,000-rpm
  • High-performance option
  • High accel/decel rates
  • 5000-rpm rigid tapping
  • 20% faster speeds and feeds
  • Better performance for 3D profiling
15,000-rpm
  • 50% faster speeds and feeds
  • Best performance for 3D profiling
20,000-rpm
  • 100% faster speeds and feeds
  • Ultimate performance for 3D profiling
Note: The optional high-performance spindles have a higher power requirement than the standard spindle. Contact your local HFO for information.
See the DT/DM Series in Action
VMC Comparison
Watch as we show three of the most popular Haas mills run the same part, and see which machine finishes first.
Introducing the DM-1
The DM-1 Drill/Mill Center provides the same high speed and performance as our shop-proven DT-1 Drill/Tap Center, but with a larger 40-taper inline spindle and 18+1 tool changer.
Meet your new compact 5-axis
If you make small parts and have multiple setups, this rotary is the perfect solution. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shop’s efficiency.
The DM-2 and DT-2
Bob and Bryan talk about the new Haas DM-2 and DT-2, and show a great cutting demo that highlights the machines’ features, like 2400 ipm rapids and tool changes in less than 1 second.
Other Similar Machines
