  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
      • Compact Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Lathe Turret Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Mini Mill - UK
Mini Mill-UK
    CNY ONLY
    CNY ONLY
Mini CNC Vertical Mill with 16" x 12" x 10" travels
  • 40 Taper
  • 3 Axis
  • 4k RPM
  • 10 Tool Capacity
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • Gallery
  • Send Info
  • Installation Guide
  • Layout Drawing
  • Operator’s Manual
  • MM Series Flyer
  • Rotary Fit Chart
  • Rotary Fit Chart
  • Automatic Workholding and Configuration Chart
Standard Features
  • 4000-rpm Spindle
  • 10-Pocket Carousel Tool Changer
  • Window Air Blast
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • Safe Run
  • HaasDrop
  • Work Light
Shipping
  • Export Packaging
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
Haas Mini Mills are the industry standard for compact machining centers. They provide an economical solution for small parts machining in a compact package that is loaded with full-size features. The Mini Mill-UK is perfect for small shops, as a second-op machine, or as a first step into CNC machining.
Our UK Models are special configurations of our best-selling machines that we’re offering at our lowest prices ever, exclusively for the UK market – so you can experience Haas quality, performance, and value first hand.
  • Available exclusively in the UK
  • 4000-rpm spindle
  • 300 ipm (76.2 m/min) rapids
  • Built with the same high-quality components as the standard Mini Mill
  • Made in the USA
NOTE: The Through-Spindle Coolant option requires 3-Phase power.
Introduction to the Mini Mill
This super-popular, small-footprint machine has proved successful in small and large shops alike. Bob and Bryan talk about the improvements made to increase reliability and make the machine even easier to use.
Travels S.A.E METRIC
X Axis 16.0 in 406 mm
Y Axis 12.0 in 305 mm
Z Axis 10.0 in 254 mm
Spindle Nose to Table (~ max) 14.0 in 356 mm
Spindle Nose to Table (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 7.5 hp 5.6 kW
Max Speed 4000 rpm 4000 rpm
Max Torque 33.0 ft-lbf @ 1200 rpm 45.0 Nm @ 1200 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper CT or BT 40 CT or BT 40
Table S.A.E METRIC
Length 36.0 in 914 mm
Length (Work Area) 28.75 in 730 mm
Width 12.0 in 305 mm
T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
T-Slot Center Distance 4.33 in 110 mm
Number of Std T-Slots 3 3
Max Weight on Table (evenly distributed) 500 lb 227 kg
Feedrates S.A.E METRIC
Max Cutting 300 ipm 7.6 m/min
Rapids on X 300 ipm 7.6 m/min
Rapids on Y 300 ipm 7.6 m/min
Rapids on Z 300 ipm 7.6 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2000 lbf 8896 N
Max Thrust Y 2000 lbf 8896 N
Max Thrust Z 2000 lbf 8896 N
Tool Changer S.A.E METRIC
Type Carousel Carousel
Capacity 10 10
Max Tool Diameter (full) 3.5 in 89 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 4.2 s 4.2 s
Chip-to-Chip (avg) 5.0 s 5.0 s
General S.A.E METRIC
Coolant Capacity 40 gal 151 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 91 in x 64 in x 99 in 231 cm x 163 cm x 251 cm
Export Pallet 91 in x 64 in x 99 in 231 cm x 163 cm x 251 cm
Weight 4000 lb 1820.0 kg
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Roll over image to zoom in
Need More Information?
HAAS VISE OPTIONS AND CONFIGURATIONS CHART
AIR VISES | HYDRAULIC VISE | ELECTRIC VISES
Other Similar Machines
Faster Spindle
Haas Mini Mill
Mini Mill
  • 40 Taper
  • 3 Axis
  • 6k RPM
  • 10 Tool Capacity
    CNY ONLY
Learn More Build & Price
LARGER WORK ENVELOPE
Haas Mini Mill 2
Mini Mill 2
Mini Vertical Mill with 20" x 16" x 14" travels
  • 40 Taper
  • 3 Axis
  • 6k RPM
  • 20 Tool Capacity
    CNY ONLY
HIGHER PRODUCTION
Haas Super Mini Mill
Super Mini Mill
Super-Speed Mini Vertical Mill with 16" x 12" x 10" travels
  • 40 Taper
  • 3 Axis
  • 10k RPM
  • 10 Tool Capacity
    CNY ONLY
The updated haas mini mill
The Haas Mini Mill has been popular for years as a small-footprint, affordable, highly capable CNC mill. Now, Haas has redesigned the machine from the ground up, watch this video to see all the improvements.
Set Tool and Work Offsets
With the Haas Wireless Intuitive Probing System (WIPS), you can set tool and work offsets in a fraction of the time. No more edge finders or slips of paper under the tool needed.
Meet the new TRT100 Rotary
If you make small parts and have multiple setups, this rotary is the perfect solution. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shop’s efficiency.
On-Screen Work Instructions
With M130, you can display setup sheets, tool lists, work instructions, and even videos – all within your program. No more taping work instructions to the machine, or hand writing notes telling your operator how to load or inspect a part; put it all in your NC program!
Replacement Parts
Replace worn out parts on your machine with genuine OEM parts. We have thousands in stock and ready to ship.
SHOP NOW
Performance Upgrades
Make your Haas machine perform even better, with high-productivity options that can be installed at your shop.
SHOP NOW
Maintenance Upgrades
Make your machine easier to operate, while reducing downtime. A variety of solutions are available.
SHOP NOW
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
