  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Automation HTEC Network Industry 4.0 Haas Certification
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Part #
      Mill Toolholding Milling Holemaking Threading Lathe Tooling Tooling Accessories Mill Workholding Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    18. اللغة العربية
    19. Български
Search
UMC-1000-V
Product Image
GET QUOTE
UMC-1000-V
    CNY ONLY
    CNY ONLY
5-Axis CNC Vertical mill with 40" x 25" x 25" travels
  • 40 Taper
  • 5 Axis
  • 10k RPM
  • 30+1 Tool Capacity
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Details
  • Specs
  • Gallery
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
  • UMC-1000 Series Flyer
Standard Features
  • 10,000-rpm Spindle
  • 30+1 Side-Mount Tool Changer
  • Wireless Intuitive Probing System
  • Belt-Type Chip Conveyor UMC
  • 55-Gallon Coolant Tank
  • Through-Spindle Coolant Ready
  • Variable Flow Coolant
  • CNC Control Cabinet Cooler
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • Safe Run
  • HaasDrop
  • Remote Jog Handle with Touchscreen Display
  • Rigid Tapping
  • Dynamic Work Offsets and Tool Center Point Control
  • Second Home Position
  • Rotary Scales
  • Top Cover for UMC Series
Warranty
  • 1-Year Standard Warranty
Available Options
5-axis machining is an effective means to reduce setups and increase accuracy for multi-sided and complex parts. The larger travels and bigger platter of the Haas UMC-1000 Series Universal Machining Centers make them perfect solutions for 3+2 machining and simultaneous 5-axis machining of large parts.
Our V Models are special configurations of our best-selling UMC models that we’re offering at our lowest prices ever, exclusively for the Chinese market – so you can experience Haas quality, performance, and value first hand.
  • 5-axis simultaneous machining
  • 10,000-rpm inline direct-drive spindle
  • Large-capacity side-mount tool changer
  • Belt-type chip conveyor
  • Through-spindle coolant ready
  • Includes Wireless Intuitive Probing System
  • Made in the USA
BIGGER PARTS? NO PROBLEM!
The UMC-1000 is the perfect choice for shops wanting an easy-to-use 5-axis solution to handle larger parts. It offers the same shop-proven performance and value as our super popular UMC-750, but with larger travels and a bigger platter.
8-Station Pallet-Pool
Add a pallet-pool to your UMC-1000/SS to take your production to the next level. With 8 additional pallets, you can ensure your machine will be running “lights out.”
Overview
The UMC-1000 offers larger travels and a bigger platter than the UMC-750, and incorporates a number of design improvements.
Universal Machining Center Design Improvements:
  • Cycloidal Rotary Drives
  • Lighter Operator Door
  • Front-Mounted Control Pendant
  • Easy-Access Operator Convenience Features
  • Larger Side-Window
  • Stiffer Base Casting
  • Standard Rollaway Coolant Tank
The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability on both the B and C axes. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
Operator Door Improvements
The UMC-1000 door mounts inside the enclosure, which raises the bottom of the enclosure opening, and provides better chip control.
Control Pendant Mount
The internal mounting design of the UMC-1000 door allows the control pendant to be mounted to the front of the machine, in an operator-friendly position.
The UMC-1000’s operator convenience features are mounted to the front of the machine for easy access, including a toolholder storage rack, work table, toolholder vise, storage tray, and washdown hose.
Side-Window Design
Moving the control pendant to the front of the UMC-1000 allowed us to enlarge the side window and make it slide open. This provides access to the machine’s platter, and also allows a pallet pool or other automation to be added to the machine.
Base Casting and Coolant Tank
The UMC-1000 base casting is stiff and compact, improving cut performance, and allowing the use of our standard 55-gallon (208 liter) rollaway coolant tank, for easy cleaning and maintenance. An optional 95-gallon (360 liter) coolant tank is also available, and both tanks accept our Oil Skimmer and Coolant Refill options to further enhance productivity.
Travels S.A.E METRIC
X Axis 40.0 in 1016 mm
Y Axis 25.0 in 635 mm
Z Axis 25.0 in 635 mm
Spindle Nose to Platter (~ max) 29.0 in 737 mm
Spindle Nose to Platter (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 10000 rpm 10000 rpm
Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Liquid Cooled Liquid Cooled
B Axis – Tilt S.A.E METRIC
Travel 120 ° to 35- ° 120 ° to 35- °
Max Speed 50 °/sec 50 °/sec
Max Torque 2240 ft-lbf 3037 Nm
Brake Torque 2000 ft-lbf 2712 Nm
C Axis – Rotation S.A.E METRIC
Travel 360 ° 360 °
Max Torque 1854 ft-lbf 2514 Nm
Max Part Swing 34.0 in 864 mm
Brake Torque 900 ft-lbf 1220 Nm
Platter S.A.E METRIC
Platter Diameter 25.00 in 635 mm
Max Weight on Platter 1000 lb 454.0 kg
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 4.92 in 125 mm
Number of Std T-Slots 7 7
Feedrates S.A.E METRIC
Max Cutting 650 ipm 16.5 m/min
Rapids on X 900 ipm 22.9 m/min
Rapids on Y 900 ipm 22.9 m/min
Rapids on Z 900 ipm 22.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 3300 lbf 14680 N
Max Thrust Y 3300 lbf 14680 N
Max Thrust Z 4050 lbf 18015 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 5.0 in 127 mm
Max Tool Length (from gage line) 12 in 305 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 2.8 s 2.8 s
Chip-to-Chip (avg) 3.6 s 3.6 s
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 168 in x 94 in x 116 in 427 cm x 239 cm x 295 cm
Export Pallet 165 in x 92 in x 101 in 420 cm x 234 cm x 257 cm
Weight 15600 lb 7077.0 kg
Domestic Pallet for Sheet Metal Crate 102 in 63 in 34 in 260 cm 161 cm 87 cm
Export Pallet for Sheet Metal Crate 102 in 63 in 34 in 260 cm 161 cm 87 cm
Weight for Sheet Metal Crate 1164 lb 528 kg
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 30.0 hp 22.4 kW
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Other Similar Machines
Haas UMC-750
UMC-750 SMALLER WORK ENVELOPE
5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30-50 Tool Capacity
    CNY ONLY
Learn More Build & Price
Product Image
VF-6/40TR DIFFERENT APPROACH
Trunnion CNC Vertical Mill with 64" x 32" x 30" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
    CNY ONLY
Haas UMC-1000
UMC-1000SS HIGHER PRODUCTION
Super-Speed 5-Axis CNC Vertical Mill with 40" x 25" x 25" travels
  • 40 Taper
  • 5 Axis
  • 12k RPM
    CNY ONLY
Dynamic Work Offsets + Tool Center Point Control = Making 5-Axis Easier
Standard On All UMC Series Universal Machining Centers
WITH DWO/TCPC THERE’S NO NEED TO:
✗   Place the part in the exact same location every time
✗    Repost the program when the fixture changes
✗    Repost the program if the job moves to another Haas machine
DWO/TCPC CHANGES EVERYTHING:
✓   Save time on programming and setup
✓   Reduce fixturing costs
✓   Increase your number of multi-axis operators
✓   Increase your productivity and profits
Available 8-Station Pallet Pool
Whether you’re doing high-volume production runs, high-mix/low volume machining, or just want to run lights-out, you can boost the productivity of your UMC-1000 with our fully integrated 8-station pallet pool.
LEARN MORE
HAVE UMC-1000 QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • Rotary Fit Chart
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
