  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Automation HTEC Network Industry 4.0 Haas Certification
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Part #
      Mill Toolholding Milling Holemaking Threading Lathe Tooling Tooling Accessories Mill Workholding Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    18. اللغة العربية
    19. Български
Search
UMC-750-V
Product Image
GET QUOTE
UMC-750-V
    CNY ONLY
    CNY ONLY
5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 5 Axis
  • 10k RPM
  • 30+1 Tool Capacity
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Details
  • Specs
  • Gallery
  • Send Info
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
  • UMC Series Flyer
Standard Features
  • 10,000-rpm Spindle
  • 30+1 Side-Mount Tool Changer
  • Wireless Intuitive Probing System
  • Belt-Type Chip Conveyor UMC
  • 55-Gallon Coolant Tank
  • Through-Spindle Coolant Ready
  • Variable Flow Coolant
  • CNC Control Cabinet Cooler
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • Safe Run
  • HaasDrop
  • Remote Jog Handle with Touchscreen Display
  • Rigid Tapping
  • Dynamic Work Offsets and Tool Center Point Control
  • Second Home Position
  • Rotary Scales
  • Top Cover for UMC Series
Warranty
  • 1-Year Standard Warranty
Available Options
5-axis machining is an effective means to reduce setups and increase accuracy for multi-sided and complex parts. The Haas UMC Series universal machining centers are cost-effective solutions for 3+2 machining and simultaneous 5-axis machining. The UMC-750 has an integrated dual-axis trunnion table with a 500 mm diameter platter that features standard T-slots and a precision pilot bore for fixturing versatility. The trunnion provides +120 and -35 degrees of tilt and 360 degrees of rotation to provide excellent tool clearance and large part capacity.
Our V Models are special configurations of our best-selling UMC models that we’re offering at our lowest prices ever, exclusively for the Chinese market – so you can experience Haas quality, performance, and value first hand.
  • 5-axis simultaneous machining
  • 10,000-rpm inline direct-drive spindle
  • Large-capacity side-mount tool changer
  • Belt-type chip conveyor
  • Through-spindle coolant ready
  • Includes Wireless Intuitive Probing System
  • Made in the USA
Universal Machining Center Design Improvements
Engineering Manager Eric Wood talks with Bryan O’Fallon about all of the features that have been changed on the newly released UMC-750 and 750SS. Highlighted by a new operator door and available HSK spindle, Eric also addressed issues like user friendliness, increased performance, better chip evacuation, rotary crash worthiness, and much more.
UMC-750 at Work
Complex parts are perfect for the UMC-750. With its generous travels and 5-axis capabilities, you’ll easily reduce setups and part handling, while increasing feature-to-feature accuracy.
Overview
The UMC-750 and UMC-750SS have been redesigned to incorporate all the design improvements engineered into our larger UMC-1000 and smaller UMC-500 – completing the upgrade of our full line of 5-axis universal machining centers.
Universal Machining Center Design Improvements:
  • Cycloidal rotary drives
  • Lighter operator door
  • Front-mounted control pendant
  • Easy-access operator convenience features
  • Larger side-window
  • Stiffer base casting
  • Standard rollaway coolant tank
Cycloidal Rotary Drives
The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability on both the B and C axes. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
Operator Door and Control Pendant
The UMC-750 door now mounts inside the enclosure, which raises the bottom of the enclosure opening, and provides better chip control. The internal mounting design of the door allows the control pendant to be mounted to the front of the machine, in an operator-friendly position.
Operator Convenience Features
The UMC-750’s operator convenience features are mounted to the front of the machine for easy access, including a toolholder storage rack, work table, toolholder vise, storage tray, and washdown hose.
Side-Window Design
Moving the control pendant to the front of the UMC-750 allowed us to enlarge the side window and make it slide open. This provides access to the machine’s platter, and also allows a pallet pool or other automation to be added to the machine.
Base Casting and Coolant Tank
The UMC-750 base casting is stiff and compact, improving cut performance, and allowing the use of our standard 55-gallon (208 liter) rollaway coolant tank, for easy cleaning and maintenance. The coolant tank also accepts our Oil Skimmer and Coolant Refill options to further enhance productivity.
Travels S.A.E METRIC
X Axis 30.0 in 762 mm
Y Axis 20.0 in 508 mm
Z Axis 20.0 in 508 mm
Spindle Nose to Platter (~ max) 24.0 in 610 mm
Spindle Nose to Platter (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 10000 rpm 10000 rpm
Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Liquid Cooled Liquid Cooled
B Axis – Tilt S.A.E METRIC
Travel 120 ° to 35- ° 120 ° to 35- °
Max Speed 50 °/sec 50 °/sec
Max Torque 2240 ft-lbf 3037 Nm
Brake Torque 2000 ft-lbf 2712 Nm
C Axis – Rotation S.A.E METRIC
Travel 360 ° 360 °
Max Torque 1854 ft-lbf 2514 Nm
Max Part Swing 27.0 in 686 mm
Brake Torque 900 ft-lbf 1220 Nm
Platter S.A.E METRIC
Platter Diameter 19.70 in 500 mm
Max Weight on Platter 660 lb 300.0 kg
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 2.48 in 63 mm
Number of Std T-Slots 7 7
Feedrates S.A.E METRIC
Max Cutting 650 ipm 16.5 m/min
Rapids on X 900 ipm 22.9 m/min
Rapids on Y 900 ipm 22.9 m/min
Rapids on Z 900 ipm 22.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2750 lbf 12233 N
Max Thrust Y 2750 lbf 12233 N
Max Thrust Z 3400 lbf 15124 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 5.0 in 127 mm
Max Tool Length (from gage line) 12 in 305 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 2.8 s 2.8 s
Chip-to-Chip (avg) 3.6 s 3.6 s
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 168 in x 93 in x 110 in 427 cm x 235 cm x 280 cm
Export Pallet 169 in x 92 in x 100 in 429 cm x 234 cm x 254 cm
Weight 14250 lb 6463.8 kg
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 30.0 hp 22.4 kW
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Talk to Us
Other Similar Machines
Haas UMC-750SS
UMC-750SS HIGHER PRODUCTION
Super-Speed 5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 5 Axis
  • 12k-15k RPM
  • 30-50 Tool Capacity
    CNY ONLY
Learn More Build & Price
Haas VF-540TR
VF-5/40TR DIFFERENT APPROACH
Trunnion CNC Vertical Mill with 50" x 26" x 25" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
    CNY ONLY
Haas UMC-1500_DUO
UMC-1500-DUO DIFFERENT APPROACH
5-Axis Dual-Station Vertical Machining Center; 60" x 20" x 20"
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
    CNY ONLY
Dynamic Work Offsets + Tool Center Point Control = Making 5-Axis Easier
Standard On All UMC Series Universal Machining Centers
WITH DWO/TCPC THERE’S NO NEED TO:
✗   Place the part in the exact same location every time
✗    Repost the program when the fixture changes
✗    Repost the program if the job moves to another Haas machine
DWO/TCPC CHANGES EVERYTHING:
✓   Save time on programming and setup
✓   Reduce fixturing costs
✓   Increase your number of multi-axis operators
✓   Increase your productivity and profits
HaasBuilt - UMC-750
Take a closer look at how your UMC-750 is built and assembled from the ground up, straight from our factory in Oxnard, California!
Maintain Your Machine
Replacement Parts
Replace worn out parts on your machine with genuine OEM parts. We have thousands in stock and ready to ship.
SHOP NOW
Performance Upgrades
Make your Haas machine perform even better, with high-productivity options that can be installed at your shop.
SHOP NOW
Maintenance Upgrades
Make your machine easier to operate, while reducing downtime. A variety of solutions are available.
SHOP NOW
FIND DISTRIBUTOR
  • Rotary Fit Chart
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
