  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    3. Español
    13. Русский
Search
VMT-750
Product Image
GET QUOTE
VMT-750
    CNY ONLY
    CNY ONLY
Vertical Mill/Turn Machining Center; 31" x 16.5" x 25" travels
  • HSK-T/A63 Taper
  • 5 Axis
  • 8.1k RPM
  • 50+1 Tool Capacity
Coming soon. Contact your local HFO for availability.
Note: Spindle-nose-to-table dimensions (minimum and maximum) will vary with the orientation of the spindle. See Machine Layout Drawing.
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • INSTALLATION Guide
  • Layout Drawing
  • Torque Chart
Standard Features
  • 8100-rpm Spindle, HSK-A63, Grease Packed
  • 50+1 Side-Mount Tool Changer, HSK
  • Wireless Intuitive Probing System
  • Automatic Tool Presetter
  • Window Air Blast
  • Chip Auger
  • 55-Gallon Coolant Tank
  • Through-Spindle Coolant
  • CNC Control Cabinet Cooler
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • Safe Run
  • HaasDrop
  • Rigid Tapping
  • Dynamic Work Offsets and Tool Center Point Control
Shipping
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
The Haas VMT-750 vertical mill/turn center combines the rigid structure of our VF-5 vertical machining center with the robust spindle of our ST-15 big-bore turning center to create a versatile multi-tasking center for machining medium-sized complex parts in a single setup.
  • Mill and turn complex parts in a single setup
  • HSK-T/A63 taper spindle w/brake for turning operations
  • +8 to -90º B-axis spindle rotation, interpolated or positioning
  • Includes through-spindle coolant system
  • Made in the USA
Travels S.A.E METRIC
X Axis 25.0 in 635 mm
Y Axis - Mill/Turn 13.0- in to 3.5 in 330- mm to 89 mm
Z Axis 31.0 in 787 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 8100 rpm 8100 rpm
Max Torque 150.0 ft-lbf @ 500 rpm 203.0 Nm @ 500 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper HSK-63A/T HSK-63A/T
Bearing Lubrication Grease Packed Grease Packed
Cooling Air Cooled Air Cooled
B Axis - Tilt S.A.E METRIC
Travel +8˚to - 90˚ +8˚to - 90˚
Max Speed 50 °/sec 50 °/sec
Max Torque 1854 ft-lbf 2514 Nm
Brake Torque 1200 ft-lbf 1626 Nm
Spindle - Turning S.A.E METRIC
Chuck Size 8.3 in 210 mm
Spindle Nose A2-6 A2-6
Max Rating 30.0 hp 22.4 kW
Max Speed 4000 rpm 4000 rpm
Max Torque 160.0 ft-lbf @ 500 rpm 217.0 Nm @ 500 rpm
Bar Capacity 2.50 in 64 mm
Spindle Bore ø 3.50 in 89.0 mm
Max Weight on Chuck (unsupported) 150 lb 68 kg
Main Spindle C Axis S.A.E METRIC
Max Rating 5.0 hp 3.7 kW
Positioning (±) 0.02 ° 0.02 °
Brake Clamp Force 2164 lbf 9626 N
Brake Diameter 14.4 in 366 mm
Brake Holding Torque 140 ft-lbf 190 Nm
Control Type Interpolated Motion and Positioning Interpolated Motion and Positioning
Table S.A.E METRIC
Length 54.0 in 1372 mm
Width 24.0 in 610 mm
T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
T-Slot Center Distance 3.15 in 80 mm
Number of Std T-Slots 7 7
Max Weight on Table (evenly distributed) 1000 lb 454 kg
Feedrates S.A.E METRIC
Max Cutting 500 ipm 12.7 m/min
Rapids on X 710 ipm 18.0 m/min
Rapids on Y 710 ipm 18.0 m/min
Rapids on Z 710 ipm 18.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2550 lbf 11343 N
Max Thrust Y 4100 lbf 18238 N
Max Thrust Z 4100 lbf 18238 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 5.0 in 127 mm
Max Tool Length (from gage line) 13 in 330 mm
Max Tool Length (probeable) 10.9 in 277 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 1.8 s 1.8 s
Chip-to-Chip (avg) 2.4 s 2.4 s
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 168 in x 99 in x 125 in 427 cm x 251 cm x 318 cm
Weight 15360 lb 6967.0 kg
Spindle Speed 8100 rpm 8100 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Spindle Power 15.0 hp 11.2 kW
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Other Similar Machines
Turning Center Alternative
Haas ST-20Y
ST-20Y
Y-Axis CNC Lathe with 11.75" x 22.5" max capacity and 2.5" bar capacity
  • 8.3" Chuck Size
  • 2.5" Bar Capacity
  • 4k RPM
  • 20 hp Power
    CNY ONLY
Learn More Build & Price
A DIFFERENT APPROACH
Haas UMC-500
UMC-500
5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Haas VR-8
VR-8
5-Axis Vertical Machining Center; 64" x 40" x 42", 2-axis head
  • HSK-A63 Taper
  • 5 Axis
  • 20k RPM
    CNY ONLY
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
