  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
25 - NGC - HaasDrop
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration and Patch Files
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - WorkLights and HIL
  • 22 - NGC - CabCool
  • 23 - NGC - HaasConnect
  • 24 - NGC - Networking
  • 25 - NGC - HaasDrop
  • 26 - NGC - 8M PCB
  • 27 - NGC - Robot and Automation
  • 28 - NGC - Machine Data Collection
  • 29 - NGC - Control Icons
  • 30 - NGC - Sensors and Switches
  • 31 - NGC - USB
  • HaasDrop - Installation
  • HaasDrop - Troubleshooting
What Is HaasDrop?
The HaasDrop application is used for sending files from a iOs or Android device to the control (NGC) on a Haas Machine.
Machine Requirements:
  • Software version 100.19.000.1301 or higher.
  • Wireless Networking Option
Mobile Device Requirements:
iOS
  • iOS 11 or above.
  • Wi-Fi connectivity.
Android
  • Android 6.0 Marshmallow or above.
iOS Device Setup
Download and install the HaasDrop application from the Apple App store.
Press [SETTING] , navigate to the Network > Haas Drop [1].
Press [F4] to Enable Haas Drop.  A QR code [2] will appear on the screen .
Open the HaasDrop application and select Scan QR Code [3].
Scan the QR code on the Haas control. A pop will show "HaasDrop" wants to Join Wi-Fi Network... Select Join [4] to continue.
Select the + or the Add Files [1] to select files.
Select the type of file:
  • Photo - This allows you to capture a photo directly from HaasDrop.
  • Video - This allows you to capture a video directly from HaasDrop.
  • Photos Library - This shows you the photos and videos stored on your IOS device.
  • Files - This shows zip, pdf, txt, and nc files on the Files app for your iOS device.
Select the files you want to transfer [2].  Select Done [3] to continue.
Enter the file name and select Save [4] to continue.  This allows you to rename the file you are sending to the control.
Select Drop [5] to save the file to the Haas Control.  The file will be saved on the User Data tab, on My Media folder.
You can now display the media file in your program using a M130/M131 code.  Refer to the M130 Display Media / M131 Cancel Display Media help page for more information.
Android Device Setup
Download and install the HaasDrop application from the Google Play Store.
Open the HaasDrop application. A popup will show "Allow HaasDrop to access this device.." select Allow [3] to continue.
Select Scan QR Code [4].
Scan the QR code on the Haas control [5].
Select the Add Files [1] to select files.
Select the type of file [2] :
  • Media File - This shows you the photos and videos stored on your Android device.
  • Files - This shows zip, pdf, txt, and nc files on your Android device.
Select the Drop Icon [5] to save the file to the Haas Control.  The file will be saved on the User Data tab, on My Media folder.
Troubleshooting
Refer to the HaasDrop - Troubleshooting Guide - NGC for troubleshooting information.
Overview
 Help:   If you need further assitance with HaasDrop please send an email to [email protected].
Could not connect my HaasDrop App to the machine. The WIFI connection got corrupted. Turn off/on the Wifi on your mobile device then try again.  If it still won't connect restart your phone and cycle the power on the machine.
The wireless network signal is weak.  Confirm the network connectivity is strong when using Wi-Fi.
The wired and wireless connection are Enabled at the same time. Use only one connection method wired or wireless.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
