  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
8 - UMC - Axis Compensation
UMC-Series - Service Manual
  • 1 - UMC - Introduction
  • 2 - UMC - Specifications
  • 3 - UMC-500/750/1000 - Installation
  • 4 - UMC-1500-DUO/1600-H - Installation
  • 5 - UMC - Anchoring
  • 6 - UMC - Operation
  • 7 - UMC - Geometry and Alignment
  • 8 - UMC - Axis Compensation
  • 9 - UMC - MRZP and Safe Zones
  • 10 - UMC - B/C - Rotary Axis
  • 11 - UMC - Tool Changer
  • 12 - UMC - Chip Removal and Coolant
  • 13 - UMC - Electrical Control
  • 14 - UMC - Lubrication
  • 15 - UMC - Maintenance
  • 16 - UMC - Pallet Pool
  • 17 - UMC - Hydraulic Workholding
  • 18 - UMC - Pneumatic Workholding
  • 8.1 UMC Thermal Sensor - Installation
UMC Thermal Growth Sensor - Install
AD0515
This procedure will go over how to install the thermal growth sensor on any vertical UMC machine. This includes accessing the installation area, preparing the area, installing the sensor, and configuring software/firmware for this sensor.
Machine Requirements:
  • Software to 100.20.000.1100 or higher.
  • Update the I/O PCB main firmware to the latest version depending on the I/O PCB hardware version.  Refer to the I/O PCB Firmware Update procedure.
This document applies to the following service kits:
  • 93-3228 Sensor Based Compensation Kit UMC-500
  • 93-3232 Sensor Based Compensation Kit UMC-750
  • 93-3233 Sensor Based Compensation Kit UMC-1000
The thermal growth sensor mounts directly to the spindle head casting. To access the casting you will need to remove the coolant knob [1] and spindle head covers [2 & 3].
Remove the Peel & Seal patches shown [1 & 2]
Mount the thermal growth sensor onto the casting in the orientation shown
Find the smaller Peel and Seal patch (4" X 4") and vinyl foam tape inside the service kit.
Place vinyl foam tape onto the center area of the sticky side of the Peel and Seal patch.
Leave roughly a 1" border of exposed, sticky, Peal and Seal patch around the vinyl foam tape.
This is a view from inside the spindle head casting.
Apply the smaller Peel & Seal patch, with insulating vinyl foam tape, onto the mounted sensor inside the casting [1].
No part of the patch should touch the front face of the casting.
The vinyl foam tape should be between the sensor and the patch.
First add a ferrite filter to cable 33-2232 and plug it into p45 on the I/O board.
Next, route cable 33-2232 from the I/O board, along the spindle motor power cable, up to the junction box/panel shown.
Mount the end of this cable to the junction box/panel in spare slot #2 highlighted in red.
Next, route the sensor cable along the spindle motor power cable, to the top of the spindle head casting
Apply dielectric grease into each plug then plug the end of the sensor cable into spare slot #2 highlighted in red joining the two cables.
This connects the sensor cable to the cable routed earlier (33-2232) from P45 on the I/O board.
Apply replacement Peel & Seal patches to the openings shown.
Re-install the spindle head covers and coolant knob.
Apply the patch included in the service kit, and upload current configuration files, then verify by going to Current Commands, then Timers, then cheking that "Macro Label #1" reads "1.0" and "Macro Assign #1" reads "32270".
Last, Check the I/O page for A-Input 10. The value should read between 350 and 800.
  •    If = between 0 and 100, check connections, check plug, and check if firmware is latest version available for the machine's I/O board.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
