    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Fixture Clamps
      • Toolmakers Vise
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Plug & Ring Gauges
      • Gauge Blocks & Accessories
      • Pin Gauges & Accessories
      • Test Bars
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Automatic Control Software Update (Mill VER18 and Lathe VER11)
Service Home How To Procedures Automatic Control Software Update (Mill VER18 and Lathe VER11)
Recently Updated Last updated: 11/27/2018
Applies to machines built from: December, 2010
- Jump to Section - 1. Introduction 2. Control Software Load (3 steps) 3. Activation (10 steps) Back to Top
This procedure is commonly called "Auto Update." It is applicable when the Maincon has software installed. It is also used to change the software to a different version.
 Important: When this procedure is completed, make sure that the correct optional functions are enabled. ENTER THE BILL TIME CODE IF AVAILABLE. If the Bill Time code is not available, be sure to increase the time to the maximum date permitted from the Haas portal.
Make sure that the Communications Firmware (Floppy Version) is 14.007 or higher. Refer to Communications Firmware Replacement for a Maincon Processor.
Make sure you have access to the Haas portal.
Get the mill or lathe software from the Haas portal:
  1. Get the Mill Control Software: Service > Documents and Software > Control Software > Mill > Mill XXX > XXX.zip
  2. Get the Lathe Control Software: Service > Documents and Software > Control Software > Lathe > Lathe XXX > XXX.zip
If you do not know how to download software, refer to Download Software from the Haas Portal.
Insert the USB memory device that contains the software files into the USB port on the pendant.
Enter DEBUG mode.
Type UPDATE.
Press [WRITE/ENTER]. The SOFTWARE UPDATE screen shows.
Press [EMERGENCY STOP].
Press [F1].
Type U for USB.
Wait until the display shows the message ENTER FILE NAME AND PRESS WRITE/ENTER KEY
Enter the file name of the software on the USB drive.
For example, type M1810C.bin.
Wait until the display shows the message PLEASE CYCLE POWER.
Press [POWER OFF].
Wait 10 seconds.
Activation
The display shows the Language File Loader screen.
Press [POWER ON].
Select a language.
Press [WRITE/ENTER] to confirm.
Press [F1] to load the selected languages.
Record the serial number, software version, and activation code from the MACHINE ACTIVATION screen.
Go to the Haas portal (https://portal.haascnc.com).
Select Service [1].
Select Machine Activation Codes [2].
Select Machine Software Update [3].
Type the serial number into the Serial Numberfield [4].
Select Get Machines [5].
Make sure the correct machine is shown on the screen [6].
Select Next [7].
Update all information on the page, then select Next [1].
Enter the activation code.
In the Reason for Upgrading field [1], include the software issue title and reference number from the release notes [2].
Select Next.
Review the information.
If the information is correct, select Submit [1].
Record the activation code [1]. Example: JWXY7
Enter the activation code into the machine activation page.
If you see this message, press [CANCEL] to continue.
Repeat the code entry process for the other parameters: 183 SP MAX FREQ, 1287 SPINDLE MAX BEARING RPM, and 1288 SPINDLE RPM MAX FREQUENCY.
Download the parameters from the machine and run the Parameter Checker Program.
Cycle the power.
 Note: Make sure the parameter values for this software version are correct.
Procedures Necessary after a Control Software Update
After you install and initialize the software and use the Parameter Checker Program, do these procedures:
  • Zero Return All Axes
  • Side-Mount Tool Changer - Spindle Orientation Offset - Parameter 257
  • Umbrella Tool Changer - Spindle Orientation Offset - Parameter 257
  • VMC Side-Mount Tool Changer - Set Parameter 64 - Z Axis Tool Change Offset
  • Umbrella Tool Changer - Set Parameter 64 - Z Axis Tool Change Offset
  • Test the spindle RPM
  • Test coolant operation
  • Test the chip auger
  • Wireless Intuitive Probe System (WIPS) Calibration
  • Test the remote jog handle
  • Test the tool changer
 Note: When all of these procedures are completed, cycle the power (1) time.
 Note: To operate correctly, a replacement Maincon must have a Mocon firmware version that is the same as, or higher than, the version of the initial Maincon. The replacement Maincon must also have the the same, or higher, Communications Firmware (“Floppy”) version. If necessary, do the Mocon Firmware Upgrade and the Communications Firmware ("Floppy Version") Replacement for a Maincon Processor.
 Note: You must create new backup files.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
