    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
BMT - Sealing Turret Porosity
Service Home How To Procedures BMT - Sealing Turret Porosity
Recently Updated Last updated: 02/16/2022
- Jump to Section - 1. Tool List 2. Modify Mechanical Plugs (3 steps) 3. Seal Turret Porosity (8 steps) Back to Top
Tool List
  • Mityvac MV8255 Hand Pump
  • 8” 3/8" OD POLYURETHANE Hose - 58-2074
  • Mechanical Plugs - 39/100 in – These are modified, see Modify Mechanical Plugs section below.
  • Sealant – Recommend ISL-500C Medium, it cures in 4 hours. Vibra-Tite 122 Oil Tolerant Threadlocker will work, but it cures in 24 hours.
  • AirGun
  • Acetone
  • Turret Push-to-Connect Adapter
    • Straight Connector, 1/8 NPT Male, 3" Long
    • FITG NPT1/8F NPT1/8F STR BRASS – 58-2746
    • FITG REDUCER NPT1/4F NPT1/8M STR BRASS – 58-3657
    • FITG LBO 3/8 X 1/4 NPT-M STR – 58-3680
Mechanical Plugs -39/100 in must be modified to plug lathe turret IN and OUT ports.
Cut the bolt of 2x plugs down to a length of 1.2" [1].
Use a belt grinder to reduce the diameter of the coolant IN plug to .36“ [2].
Use a belt grinder to reduce the diameter of the coolant OUT plug to .30" [3].
Reassemble both plugs. Use a belt grinder to taper the bottom of the rubber tube of the coolant OUT port plug [1].
Coolant Out Port [1].
Front Port [2].
Side Port [3].
Coolant In Port [4].
Install 1/8 NPT plug into front port of the leaky pocket [1].
Apply a thin layer of red grease to each rubber plug [2] [3].
Install the small diameter rubber plug into the coolant OUT port [4] and tighten wingnut finger tight.
Install the large diameter rubber plug into the coolant IN port [5] and tighten wingnut finger tight.
Spray acetone into the cross drilled hole network until it is flooded [1].
Install 1/8 NPT to Push-To-Connect adapter into turret side port [2].
Install hand pump and pressurize cross drilled hole network. Maintain pressure until acetone weeping from porosity is visible.
Remove 1/8 NPT plug from turret front port and blow out acetone with shop air.
Reinstall 1/8 NPT plug into turret front port and pressurize with the hand pump until all acetone is pushed out of the porosity.
Remove 1/8 NPT plug from turret front port [1].
Pour the sealant into the turret side port until it almost reaches the turret front port, approximately 0.68 oz (20 mL) of sealant [2].
Reinstall the 1/8 NPT into the turret front port.
Continue to fill the turret side port with sealant until the cross drilled hole network is flooded [3].
Install the 1/8 NPT to Push-To-Connect adapter [4].
Use the hand pump to pressurize the cross drilled hole network to 30 PSI.
Once sealant is observed weeping from porosity maintain pressure for 1 min.
Remove 1/8 NPT to Push-To-Connect adapter.
Turn turret on its side so that the turret front port is over a bucket [1].
Remove turret front port 1/8 NPT plug [2] and blow out excess sealant into bucket [3].
Use a shop rag to clean sealant out of turret front and side port NPT threads and remove rubber plugs from coolant in and out ports [4].
Clean the 1/8 NPT to Push-To-Connect adapter with acetone to remove sealant residue.
Allow turret to cure for the time specified of the sealant used before performing air pressure leak test.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
