    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • Haas-Tooling-Home-TEST
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Custom Rotary Configuration Setup / Rotary File Load - NGC
Service Home How To Procedures Custom Rotary Configuration Setup / Rotary File Load - NGC
Recently Updated Last updated: 05/09/2023
- Jump to Section - 1. Introduction 2. Custom Rotary Configuration Setup - NGC (10 steps) 3. Rotary File Load (3 steps) 4. Rotary Troubleshooting Guide Back to Top
This procedure tells you how to set up a custom rotary configuration. Do this procedure to set up a non-Haas rotary in a Haas machine with the Next Generation Control (NGC).
The Custom Rotary Generator generates a spreadsheet where you input the specific parameters that apply to your rotary. It then generates a custom rotary configuration file. You can then load the rotary configuration file into the machine.
The Custom Rotary Generator converts a rotary file for a machine with the Classic Haas Control (CHC) to a rotary file for a machine with NGC.
Options Required
  • Third Party Rotary
Tools Required
  • USB Memory Device
Download File
Custom Rotary Generator V4.0.1.44
Machine Compatibility
The Custom Rotary Generator is compatible with machines that have software version 100.16.000.1021 or higher.
  • Download the CustomRotaryGenerator.zip utility to a Windows computer.
  • Unzip the file.
Open the CustomRotaryGenerator.exe utility.
Select Create Blank Spreadsheet [1].
 Note: This creates a new spreadsheet and can overwrite an existing spreadsheet.
A Browse For Folder screen opens. Select a location on your computer to save the spreadsheet. Select OK.
 Note: Opening the new spreadsheet takes approximately 15 seconds.
To open an existing spreadsheet, select Browse[2].
Find the existing spreadsheet and select Open / Edit Selected Spreadsheet [3].
A spreadsheet with the name Haas_Rotaries_Worksheet.xlsx opens.
 Note: The file name will differ if you change it.
This spreadsheet contains all of the Haas rotary configurations.
 Caution: Do not change or delete any Haas rotary configurations in gray [3].
  1. The first four columns contain parameter information. Do not edit any information in these columns.
  2. If you create a new blank spreadsheet, the fifth column is empty. Enter your rotary parameter information in this column. Each parameter must have a value for your rotary configuration files to function correctly.
  3. The columns in gray are the rotary configurations for Haas rotaries.
Name your custom rotary configuration. This example shows the name Custom-Rotary-1 [1].
 Note: The name of your rotary configuration must not contain spaces or special characters. Hyphens are permitted.
Enter all of the parameter information for your rotary configuration [2].
 Note: You can copy and paste the parameter information from a similar Haas rotary. Be sure to change the name if you copy the parameters from a Haas rotary column. You will receive an error message if you do not.
Add more columns [3] to enter more than one rotary configuration. To add another column, right click on the letter above the first gray column. Select Insert.
 Important: The columns from E to the gray columns, including those you add, are unprotected. If you delete all unprotected columns, you must go back to Step 2. All new columns are written protected after you delete the unprotected columns.
 Important: Save the spreadsheet.
If the CustomRotaryGenerator.exe utility is not open, open the CustomRotaryGenerator.exe utility.
Select Create Blank Spreadsheet [1] if one is not open already.
Select Browse [2]. Select the.ROT rotary file to convert or use the drop down [4] to select a .xml rotary file to edit.
Select Load File [3].
All of the rotary file information gets added to the spreadsheet.
 Note: The spreadsheet must be open to add the rotary file information.
The spreadsheet shows the Cold Fire Data for the rotary file [1] and the converted data [2] for the Next Generation Control. If you edit a .xml file, it only shows the rotary file data [2].
You must name the converted rotary file. This example shows the name NGC-TR310-TLT.
Go back to the Custom Rotary Generator.
Select Browse [1] to choose an XML Destination Folder.
Select Generate Custom Rotary Files [2].
The Custom Rotary Generator gives the message "Your rotary files are completed".
Select OK.
The saved rotary configuration's file location opens.
Move the rotary configuration file to a USB memory device. The rotary configuration file is an .xml file.
Rotary File Load
Insert the USB memory device with the rotary configuration file into the USB port on the control pendant.
Push [LIST PROGRAM].
Navigate to the USB tab [1].
Select your rotary configuration file [2]. Push [ENTER].
Push [F2] to copy the rotary configuration file.
Navigate to User Data [3] on the Select Device screen.
Navigate to the User Data directory.
Navigate to the My Rotary directory.
Enter the My Rotary directory [1].
Push [ENTER] [2] to copy the rotary configuration file to this location.
Push [SETTING].
Navigate to the Rotary tab [1].
Your rotary configuration file [2] appears in the Select New Rotaries page.
Refer to the Next Generation Control - Rotary - Enable and Disable to complete the Custom Rotary Setup procedure.
For more information about troubleshooitng Haas rotarys can be found in the troubleshooting chapter of our Rotary Service Manual.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
