  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
HaasDrop - Help
Service How To Procedures HaasDrop - Help
Recently Updated Last updated: 02/23/2021
HaasDrop - Help
HaasDrop - Help
What Is HaasDrop?
The HaasDrop application is used for sending files from a iOs or Android device to the control (NGC) on a Haas Machine.
Machine Requirements:
  • Software version 100.19.000.1301 or higher.
  • Wireless Networking Option
Mobile Device Requirements:
iOS
  • iOS 11 or above.
  • Wi-Fi connectivity.
Android
  • Android 6.0 Marshmallow or above.
iOS Device Setup
Download and install the HaasDrop application from the Apple App store.
Press [SETTING] , navigate to the Network > Haas Drop [1].
Press [F4] to Enable Haas Drop.  A QR code [2] will appear on the screen .
Open the HaasDrop application and select Scan QR Code [3].
Scan the QR code on the Haas control. A pop will show "HaasDrop" wants to Join Wi-Fi Network... Select Join [4] to continue.
Select the + or the Add Files [1] to select files.
Select the type of file:
  • Photo - This allows you to capture a photo directly from HaasDrop.
  • Video - This allows you to capture a video directly from HaasDrop.
  • Photos Library - This shows you the photos and videos stored on your IOS device.
  • Files - This shows zip, pdf, txt, and nc files on the Files app for your iOS device.
Select the files you want to transfer [2].  Select Done [3] to continue.
Enter the file name and select Save [4] to continue.  This allows you to rename the file you are sending to the control.
Select Drop [5] to save the file to the Haas Control.  The file will be saved on the User Data tab, on My Media folder.
You can now display the media file in your program using a M130/M131 code.  Refer to the M130 Display Media / M131 Cancel Display Media help page for more information.
Android Device Setup
Download and install the HaasDrop application from the Google Play Store.
Open the HaasDrop application. A popup will show "Allow HaasDrop to access this device.." select Allow [3] to continue.
Select Scan QR Code [4].
Scan the QR code on the Haas control [5].
Select the Add Files [1] to select files.
Select the type of file [2] :
  • Media File - This shows you the photos and videos stored on your Android device.
  • Files - This shows zip, pdf, txt, and nc files on your Android device.
Select the Drop Icon [5] to save the file to the Haas Control.  The file will be saved on the User Data tab, on My Media folder.
Troubleshooting
Refer to the HaasDrop - Troubleshooting Guide - NGC for troubleshooting information.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
