  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Auxiliary Coolant Filter - Installation - AD0111
Service Home How To Procedures Auxiliary Coolant Filter - Installation - AD0111
2.1 Auxiliary Coolant Filter - Installation
Recently Updated Last updated: 03/09/2021
AD0111
Applies to machines built from: January, 1998
Auxiliary Coolant Filter - Installation Video
This procedure tells you how to install an auxiliary coolant filter (AF) system. This #2 bag-type filter system removes contamination and small particles from the coolant before they go through the coolant pump again.
This procedure tells you how to connect the AF to these coolant systems:
  • standard coolant pump [1]
  • high pressure coolant (HPC)/Through-Spindle Coolant (TSC) 300 pump [2] with a secondary filter
  • HPC/TSC 300/1K with an Auto-Clean pump [3]
Machine Compatibility:
  • All machines excluding tool room mills and lathes.
  •  Note: The Auxiliary Filter can not be plumbed directly to the HPFC pump,  it can only be plumbed to the TSC system.
This document applies to the following service kit:
  • KIT PN: 93-1000284, AUXILIARY FILTER KIT
Prerequisites:
Do not apply thread sealant to the hose connections. This makes the hose difficult to remove.
 Note: The illustrations in this procedure show the installed configuration.
Standard Coolant Pump - Installation
If the machine has a standard coolant pump:
  • Disconnect the coolant supply hose [1], from the pump outlet [2].
  • Connect the lower supply hose [3] to the coolant supply hose [1].
  • Connect the upper AF hose [4] to the coolant pump outlet [2].
  • Close the machine doors and windows.
 Note: Coolant can splash in the machine.
  • Start the coolant pump.
  • While the coolant pump is on, open the AF lid.
 Note: This pushes the air out of the AF.
  • Close the lid when the AF is full.
HPC/TSC-300 With Secondary Filter - Installation
If the machine has a HPC/TSC 300 pump with a secondary filter:
  • Remove the coolant return loop [1].
  • Install the coolant hose adapter [A] to the 3/4" NPT port.
  • Connect the upper AF hose [2] to the coolant hose adapter.
  • Connect the 12" (30 cm) pump hose [B] to the 1/2" NPT port in the pump stand.
  • Attach the lower AF hose [3] to the 12" (30 cm) hose [B].
  • Remove the AF lid while the coolant pump is on.
  • Use the wash gun to fill the AF with the coolant.
    Note: Becareful Coolant can splash at you when using the wash gun.
  • Install the lid when the AF is full.
HPC/TSC-300/1K with Auto Clean - Installation
If the machine has HPC/TSC 300/1K and an Auto-Clean pump:
  • Connect the lower AF hose [3] to the swivel fitting on the outlet pipe.
  • Connect the upper AF hose [2] to the stand pipe [4].
Verification
Operate the standard coolant pump for (5) minutes. Check for leaks.
For maintenance information, refer to Auxiliary Filter - Bag Filter - Replacement.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
