  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
40-Taper - Spindle - Belt Drive - Drawbar Assembly - Replacement - AD0278
Service How To Procedures 40-Taper - Spindle - Belt Drive - Drawbar Assembly - Replacement - AD0278
Recently Updated Last updated: 01/17/2019
AD0278
Applies to machines built from: December, 1989
- Jump to Section - 1. Introduction 2. Replacement (1 step) Back to Top
This procedure tells you how to replace the drawbar assembly. This procedure is applicable to (5) different kits.
KIT 93-30-3410C DRAWBAR, 40T BELT DRIVE, 900 - 1300 LB
KIT 93-30-3410D DRAWBAR, 40T BELT DRIVE, 1000 - 1200 LB
KIT 93-30-3415H DRAWBAR, 40T TSC BELT DRIVE, 1750 - 2100 LB
KIT 93-30-2406A DRAWBAR, 40T BELT DRIVE (15K), 900 - 1300LB
KIT 93-30-3415F DRAWBAR, 40T BELT DRIVE, 1000 - 1200 LB
Machines with a gearbox need a hoist with at least 200lbs capacity.
Replacement
Put a toolholder without a tool in the spindle. Close the primary air valve to the machine. Remove the tool release piston (TRP) assembly [1]. Remove the retaining ring [2] from the spindle shaft. Install the TRP assembly [1]. Open the primary air valve to the machine. Remove the toolholder from the spindle. Close the primary air valve to the machine. Remove the TRP assembly [1].
If the machine has a gearbox: Remove the (6) screws [4] from the gearbox base. Use the hoist [5] to lift the gearbox and spindle motor assembly [6] until you can easily remove the drawbar [3].
Remove the used drawbar assembly [3]. Clean the bore of the spindle shaft. Make sure the balls [7] or o-rings from the used drawbar assembly [3] did not fall into the bore of the spindle shaft.
Make sure the (5) balls [7] are fully in position at the end of the replacement drawbar [3]. Lightly push the drawbar [3] to install it into the spindle shaft.
 Caution: Install the drawbar [3] with light force so you do not damage the o-rings. Do not use a tool to hit the drawbar into position.
Install the TRP assembly [1]. This lets you put a toolholder into the spindle. Open the primary air valve to the machine. Put a toolholder without a tool in the spindle. Close the primary air valve to the machine.Remove the TRP assembly [1]. Install the retaining ring [2] onto the spindle shaft.
If the machine has a gearbox: Install the (6) screws [4] into the gearbox base. Make sure the drive belts are moderately tight. If the belts are too tight, they make noise at high speeds. If the belts are too loose, they vibrate. If you cannot adjust the drive belt tension, speak to your local HFO. Torque the screws [4] on the gearbox base to 25 ft-lbs.
Install the TRP assembly [1]. Torque the screws to 45 ft-lbs.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
