    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • Haas-Tooling-Home-TEST
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter - Lathe
Service Home How To Procedures Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter - Lathe
Recently Updated Last updated: 03/10/2022
- Jump to Section - 1. Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (3 steps) 2. SL/ST/DS - Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (5 steps) 3. TL - Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (5 steps) 4. Office Lathe - Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (3 steps) Back to Top
Change the units to lbf, as follows:
  • Hold [0] and [9] and push [POWER] at the same time [1].
  • Push [SELECT] again and again until the display shows lbf.
  • Hold [POWER] until the power goes off.
  • Push [POWER] to start the meter.
To show Hz in the display for the 507C model, push [HZ] [2] again and again until the display shows Hz [3].
For the 507C model, push [MASS] [1]. For the 505C model, push [WEIGHT].
Enter the correct values from the Mass, Width, and Span columns from the Lathe - Spindle Belt Tension Specifications Document. For example, for an ST-10, push this sequence: 0, 0, 5, 5. This sets the value to 5.5 for the mass.
Loosen the (4) motor mount screws [1].
Turn the (2) belt tension screws equally until tension is in the belt.
Use your hand to tighten the motor mount fasteners.
 Note: The illustration shows the belt tension screws for an ST-20. The location of the belt tension screws for SL and other ST lathes are different.
Attach the sensor cable to the Gates sonic tension meter.
Push this button sequence on the Gates sonic tension meter:
  1. Push [POWER].
  2. Push [MEASURE].
Put the sensor less than 3/8" (11 mm) from the belt. Quickly pull your finger across the edge of the belt ("Pluck" the belt like a guitar string). Do not let the sensor touch the belt.
 Note: If you cannot make the necessary vibration with your finger, you can tap the belt with the handle of a screwdriver.
Compare the "Tension" value from the table to the value on the meter.
If the tension is too low, use the belt tension screws to tighten the belt.
If the tension is too high, use the belt tension screws to loosen the belt.
Measure the tension again, and make adjustments until the belt tension is correct.
Torque the motor mount screws. Refer to Haas Fastener Torque Specifications. Use the values for steel.
Loosen the (3) screws [1] on the plate that holds the motor.
Push down on the plate until the belt has tension.
Use your hand to tighten the (3) screws for plate.
  1. Push [POWER].
  2. Push [MEASURE].
If the lathe is a TL-3 or TL-4, go to Step 5.
For TL-1 or TL-2 lathes:
  • Find the 2 adjustment openings. Put a crowbar in one of the openings.
  • If the tension is too low, push the plate down.
  • If the tension is too high, lift the plate up.
  • Measure the tension again. Adjust the plate until the belt tension is correct.
For TL-3 or TL-4 lathes:
  • Put a jack under the plate that holds the motor.
 Caution: Make sure the jack lightly touches the plate. If the jack pushes on the plate, this can damage the motor.
  • Find the (2) adjustment openings and put a crowbar in one of the openings.
    • If the tension is too high, decrease the hieght of the the jack.
    • If the tension is too high, increase the height of the jack.
    • Measure the tension again. Make adjustments until the belt tension is correct.
Torque the (3) motor mount screws. Refer to Haas Fastener Torque Specifications. Use the values for steel.
Loosen the (6) screws [1] for the plate that holds the motor.
Push the plate to the right until the belt has tension.
Use your fingers to tighten (6) screws [1].
  1. Push [POWER].
  2. Push [MEASURE].
If the tension is too low, push the plate to the right.
If the tension is too high, push the plate to the left.
Torque the (6) screws for the plate that holds the motor. Refer to Haas Fastener Torque Specifications. Use the value for steel.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
