    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
    • Deals Of The Week
      Deals Of The Week Shop All
      • Grooving Tools
      • Cut-Off Tooling
      • Boring Bars
      • OD Toolholders
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Maincon Control Software (Mill VER 17 and Lathe VER 10) - Load
Service Home How To Procedures Maincon Control Software (Mill VER 17 and Lathe VER 10) - Load
Recently Updated Last updated: 08/24/2023
Maincon Control Software (Mill VER17 and Lathe VER10) - Load
- Jump to Section - 1. Introduction 2. Prerequisites 3. Tools Required 4. Maincon Software Load (1 step) 5. Software Version 17 (Mill) and 10 (Lathe) SAP Database Update (9 steps) 6. Backup File Installation (2 steps) 7. Option Code Activation (2 steps) 8. Procedures Necessary after a Control Software Update Back to Top
This procedure tells you how to do these tasks on any CNC machine with a Maincon PCB:
  • Install a new Maincon PCB.
  • Remove the memory and software from the Maincon PCB and install it again.
The items below list different types of software and their paths on the Haas Portal:
  1. Mill Control Software : Service > Documents and Software > Control Software > Mill > Mill XXX > XXX.zip
  2. Lathe Control Software: Service > Documents and Software > Control Software > Lathe > Lathe XXX > XXX.zip
  3. Enet Firmware version 14.007 & 14.011: Service > Documents and Software > Control Software > Mill (Classic Haas Control) > Mill 17.07A > Communications Firmware> XXX.zip
  4. Software Readme file: Service > Documents and Software > Control Software > readme Software Load.txt
  5. Software Load Assistant Guide: Service > Training > Procedure > Software Load Assistant
  6. Parameter Checker Program: Service > Documents and Software > Control Software > Parameter Program > XXX.zip
 Important: When this procedure is completed, make sure that the correct optional functions are enabled. ENTER THE BILL TIME CODE IF AVAILABLE. If the Bill Time code is not available, be sure to increase the time to the maximum date permitted from the Haas portal.
Prerequisites
Use a USB memory device with back up files created with Machine Data Backup (Mill16.xx and higher, and Lathe 9.xx and higher), check the back of the control cabinet for the USB memory stick or contact [email protected] to get the backup files.
Make sure you have access to the Haas portal (https://portal.haascnc.com).
If you do not know how to download software, refer to Software Available for Download from HAAS Portal.
Tools Required
  • USB memory device
Machine Preparation - Monitor Mode
Press [EMERGENCY STOP].
Disconnect all connections to the RS-232 serial port.
Press [POWER OFF].
Wait 10 seconds, then press and hold [PRGRM CONVRS] while you press [POWER ON].
Maincon Electrical Test
Type E.
Press [WRITE/ENTER].
Type Y at the first question [1].
Type N at the second question [2].
Type Y at the third question [3].
Press [WRITE/ENTER]. The control will conduct an electrical test.
When the test is done, press RESET.
 Note: Repeat the electrical test three times if you get the error FLASH NOT ERASED AT 1000000. If you still get this error message, replace the maincon circuit board.
Get the USB memory device that contains the correct software version. Put the USB memory device into the USB port on the pendant.
From Monitor Mode, type FC [1].
Push [WRITE/ENTER].
Wait until the display shows the message FLASH CLEAR COMPLETE [2].
Type M 6000000 6FFFFFF [3].
 Caution: Before you push WRITE/ENTER, make sure you typed this correctly. Make sure M 6000000 has 6 zeros. And make sure 6FFFFFF has 6 Fs.
Push [WRITE/ENTER].
Wait until this message shows 3 times: MEMORY TEST PASSED. PUSH RESET TO STOP. [4]
Push [RESET].
Wait until the display shows the cursor (>_).
For mill software, type N M18xxx.bin. For lathe software, type N L11xxx.bin.
For example, for mill 18.10C, type N M1810C.bin [5].
Push [WRITE/ENTER].
Type UF [6].
Push [WRITE/ENTER]. The display shows the message LOADING 00XXXXX[7].
Wait until the display shows LOAD COMPLETE [8].
Push [POWER OFF].
Find the serial number on the back plate [1].
Press [POWER ON].
Type the serial number in Setting 26 [2].
Press [POWER OFF].
Press [POWER ON].
Enter DEBUG mode.
To initialize the machine, enter the correct model.
For 40 taper machines, type VFx. For example, for a VF-1, type VF1 [1].
For 50 taper machines, type VFx. For example, for a VF-5/50, type VF550 [2].
Press [WRITE/ENTER] to reboot the machine.
 Note: You must press a key every 15 seconds or the control will turn off.
Go to the Haas portal (https://portal.haascnc.com).
Select Service [1].
Select Machine Activation Codes [2].
Select Machine Software Update [3].
Type the serial number into the Serial Number field [4].
Select Get Machines [5].
Make sure the correct machine is shown on the screen [6].
Select Next [7].
Update all information on the page, then select Next [1].
Enter the activation code.
In the Reason for Upgrading field [1], include the software issue title and reference number from the release notes [2].
Select Next.
Review the information.
If the information is correct, select Submit [1].
Record the activation code [1].
Example: PBD2G
Get the permanent unlock code from the Finance tab [1].
 Note: The finance tab requires special login permission. Contact your HFO to get this code.
Enter the permanent unlock code for Setting 26 [1].
This procedure tells you how to install the backup files from a USB memory device. The USB memory device contains backup machine files, such as .VAR, .SET, .OFS, .PAR, .ATM, .IPS, .PAL, .LSC, .PGM. files.
Press [POWER ON].
Press [SETNG/GRAPH].
Change Setting 7 to OFF.
Change Setting 23 to OFF.
Change Parameter 257 SPINDL ORIENT OFSET to 99999.
Press [LIST PROG].
Navigate to the USB DEVICE tab.
Press [F4].
Select Load all - Restore.
Enter the file name of the backup file.
Press [WRITE/ENTER] to load the backup files into the software.
Go to Parameter 257 SPINDL ORIENT OFFSET and make sure that it is not 99999.
Make sure all available options are enabled. Enter the Bill Time code if available. If the Bill Time code is not available, make sure to extend the time to the maximum allowed date per the portal.
From the Haas Portal, select the Service tab [1].
Select Option Codes [3].
Type the serial number into the field [4].
Select Submit [5].
Print the option codes for this machine.
Make sure the option codes match what the customer ordered. If the codes do not match, call Haas service.
Enable the option codes for the rest of the parameters:
All the parameter numbers for options that require unlock codes are listed below:
  1. RIGID TAP (Parameter 57:4)
  2. ENABLE ROT & SCALNG (Parameter 57:17)
  3. M19 SPINDLE ORIENT (Parameter 57:21)
  4. ENABLE MACRO (Parameter 57:22)
  5. *TSC ENABLE (Parameter 209:24)
  6. HIGH SPD MACHINING (Parameter 315:4)
  7. FOURTH AXIS (Parameter 315:14)
  8. FIFTH AXIS (Parameter 315:15)
  9. INTUITIVE PROG SYS (Parameter 315:31)
  10. ENABLE EXTENDED MEMORY (Parameter 737:2)
  11. ENABLE HARD DRIVE (Parameter 737:10)
  12. ENABLE NETWORKING Parameter 737:11
 Note: For software versions before 18.07A, TSC ENABLE does not require an unlock code.
After you install and initialize the software and use the Parameter Checker Program, do these procedures:
  • Zero Return All Axes
  • Side-Mount Tool Changer - Spindle Orientation Offset - Parameter 257
  • Umbrella Tool Changer - Spindle Orientation Offset - Parameter 257
  • VMC Side-Mount Tool Changer - Set Parameter 64 - Z Axis Tool Change Offset
  • Umbrella Tool Changer - Set Parameter 64 - Z Axis Tool Change Offset
  • Test the spindle RPM
  • Test coolant operation
  • Test the chip auger
  • Wireless Intuitive Probe System (WIPS) Calibration
  • Test the remote jog handle
  • Test the tool changer
 Note: When all of these procedures are completed, cycle the power (1) time.
 Note: To operate correctly, a replacement Maincon must have a Mocon firmware version that is the same as, or higher than, the version of the initial Maincon. The replacement Maincon must also have the the same, or higher, Communications Firmware (“Floppy”) version. If necessary, do the Mocon Firmware Upgrade and the Communications Firmware ("Floppy Version") Replacement for a Maincon Processor.
 Note: You must create new backup files.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
