  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Chuck and Tailstock - Pressure Adjustment Valve - Replacement - ST - DS - SL - AD0094
Service How To Procedures Chuck and Tailstock - Pressure Adjustment Valve - Replacement - ST - DS - SL - AD0094
Recently Updated Last updated: 12/03/2018
AD0094
Applies to machines built from: September, 2013
- Jump to Section - 1. Parts Included 2. ST/DS/SL - Chuck and Tailstock - Pressure Adjustment Valve - Replacement (2 steps) Back to Top
Parts Included
Kit: 93-2179
Quantity (QTY): 1
VALVE, HYDRAULIC PRESSURE ADJUSTMENT
 Note: The illustrations show the replacement of the chuck valve. The tailstock valve replacement is the same.
Press [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Remove the valve [1] from the valve block with a crow foot wrench [2]. Before you install the replacement valve, turn the main adjustment knob [3] on the adjustment valve counterclockwise until it stops.
Install the replacement adjustment valve with the crow foot wrench [2]. Leave the screw on the locking jam nut [4] loose.
Unlock and turn on the main circuit breaker. Press [POWER ON].
Release [EMERGENCY STOP]. Press [RESET] to start the Hydraulic Power Unit (HPU).
Refer to the link at the end of the document for the correct pressure. Do not exceed the correct pressure, or permanent damage to the chuck can occur. Slowly raise the pressure of the HPU to the correct maximum value: Turn the main adjustment knob [3] clockwise, check the pressure after each quarter turn. Repeat the process until the HPU is set to the correct pressure. The machine can generate a low pressure alarm until the correct pressure is set.
Turn the locking jam nut [4] clockwise by hand until it stops on the valve body. Rotate the valve and the locking jam nut [4] counterclockwise together until the screw on the locking jam nut [4] is accessible. Tighten the #4-40 thread screw on the locking jam nut [4] to 14 in-lb (1.6 Nm). Hold the locking jam nut [4] while you tighten the screw. Rotate the main adjustment knob [3] clockwise until the locking jam nut stops against the valve body. Make sure that the maximum pressure is correct. If the pressure is not correct, loosen the #4-40 thread screw and rotate the locking jam nut [4] to set the correct pressure.
Set the correct maximum pressure. Go to Chuck and Tailstock - Recommended Maximum Pressure.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
