  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Turret Lock and Unlocked Sensors - Adjustment - ST-10/10Y - SL-10/20/30 - TL-15/25 - HL-1/2/3/4/5/6
Service Home How To Procedures Turret Lock and Unlocked Sensors - Adjustment - ST-10/10Y - SL-10/20/30 - TL-15/25 - HL-1/2/3/4/5/6
Recently Updated Last updated: 05/09/2019
Applies to machines built from: April, 1996
- Jump to Section - 1. Introduction 2. Machine Compatibility 3. Lathe - Turret Lock Sensors - Adjustment (2 steps) 4. Lathe - Turret Unlock Sensors - Adjustment (2 steps) Back to Top
This procedure tells you how to adjust the turret locked and unlocked sensors. The procedure shows a ST-10 with software version L11.13A.
  • Turret locked sensor [1]
  • Clamp for the turret locked sensor [2]
  • Turret unlock sensor [3]
  • Clamp for the turret unlocked sensor [4]
Machine Models:
  1. ST-10/10Y
  2. SL-10/20/30
  3. TL-15/25
  4. HL-1/2/3/4/5/6
Push [EMERGENCY STOP].
Do these steps. Monitor the PARAMETER DIAGNOSTIC screen at the same time:
  1. Loosen the lock sensor clamp. Move the lock sensor and clamp up until T. Turret Locked changes to 0.
  2. Slowly move the lock sensor and clamp up. Find the location where the value is as near as possible to 1, but the value is 0.
  3. Put a mark on the turret lock cylinder on the outside of the lock sensor clamp.
  4. Repeat Step 1. Repeat Step 2, but move the clamp down. Repeat Step 3.
  5. Move the lock sensor and clamp to the middle point between the two marks. Tighten the clamp.
Push [A], [ZERO RETURN], then [SINGLE]. Make sure the T. Turret Locked value is equal to 1 . Operate this program in MDI mode.
T1;
G04 P1.;
T2;
G04 P1.;
M99;
This program makes sure the turret lock sensor operates correctly. Push [PARAM DGNOS]. Make sure that T. Turret Locked is 1 when the program operates the tool turret lock.
  1. Operate this code in MDI mode: M43 .
  2. Loosen the unlock sensor clamp.
  3. Move the unlock sensor and clamp up until Tool Turret Unl. changes to 0.
  4. Slowly move the unlock sensor and clamp up. Find the location where the value is as near as possible to 1, but the value is 0.
  5. Put a mark on the turret lock cylinder on the outside of the unlock sensor clamp.
  6. Repeat Step 3. Repeat Step 4, but move the clamp down. Repeat Step 5.
  7. Move the unlock sensor and clamp to the middle point between the two marks. Tighten the clamp.
Push [A], [ZERO RETURN], then [SINGLE]. Make sure T. Turret Locked is 1. Operate this program in MDI mode. This program makes sure the turret unlock sensor operates correctly:
T1;
G04 P1.;
T2;
G04 P1.;
M99;
Push [PARAM DGNOS]. Make sure that T. Turret Unl. changes to 1 when the program operates the tool turret unlock.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
