  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Software Update - (Option 2) - NGC
Service How To Procedures Software Update - (Option 2) - NGC
Recently Updated Last updated: 02/04/2021
NOTE:  This is procedure should only be performed by a Haas certified service technician.
This procedure tells you how to download and update the software for machines that have the Next Generation Control.
 Important: The Next Generation Control software file size is about 2.5 GB. The download time is slower for USB 2.0 than for USB 3.0 memory devices. If possible, use a USB 3.0 memory device with a computer that has a USB 3.0 port.
 Note: For a updating the software on a simulator use Next Generation Control - Simulator - Multiboot procedure. If you replace the main processor or if you cannot put the machine back into operation refer to: Software - NGC - Troubleshooting Guide.
 Note: Do not upgrade to the current software from software version 100.16.000.1020 or lower. You need to upgrade to 100.16.000.1021 first then you can upgrade to the current software version.  For any issues during the installation refer to Software - NGC - Troubleshooting Guide.
 IMPORTANT: PALLET POOL MACHINES:  Before you update the software, Go to the Pallet Schedule Table and manually record the values on the table.
Tools Required
  • Minimum of 4 GB USB Memory Device.
  • Haas Control Key
Backup and Error Report
 Note: If are performing this procedure becaused the processor failed and you could not do a backup skip this section.
Set Setting 155, Load Pocket Tables, to ON.
 Note: Make sure the memory lock key switch is in the unlocked position.
Push [LIST PROGRAM].
Select the USB tab [1].
Push [F4], System [2].
Select Back Up Machine [3].
Push [ENTER].
This screen lets you select the data files to make copies of.
 Caution: If the machine has software version 100.15.000.1011, DO NOT select User Data [2] when you make a backup. Go to the User Data tab [1]. Select the User Data files to backup. Push [F2] to copy the files to the USB memory device.
Push [ENTER] to select or deselect what you must backup.
Push [F4] to make the backup.
Get a Error Report
Press [SHIFT] then [F3]
Wait until the error report process is finished.
Software Download
Log on to the Haas Portal.
 Note: Make sure you have pop up blocker deactivated.
Select the Service tab [1].
Select Documents and Software [2].
Select Control Software [3].
Select Next Generation Control.
Select Mill, Lathe and Simulator Software.
Select the link (100.xx.xxxx.xxxx.) to download the software file.
At the prompt, enter the User Name and Password that you use to log on to the Portal.
Download and unzip the file to your USB memory device.
 Caution: Make sure you do not have another folder named HaasUpdateData in the root folder of the USB memory device.
Next Generation Control - Configuration File - Download
If you are reloading the configuration file, go to step 5.
Select Machine Activation Codes [2].
Select Machine Software Update [3].
Enter the serial number for the machine [4] and select Get Machines [5].
Select Next [6].
Make sure the MAC address [2] on this screen matches the MAC address [4] on the machine.
Push [SETTING].
Navigate to the Network tab to see the machine MAC address [4].
Select the Software Version [3] you are updating to.
Select Next [1].
Enter any number in the Machine Generated code: field [2].
Enter a reason for upgrading [3].
Select Next [1].
Review the software update information [2].
Select Submit [1].
The screen will show an activation code.
You can ignore this code.
Select NGC - Configuration [1].
Enter the machine serial number.
Select Get Details [2].
Make sure the machine information is correct [1].
For Option 5 Clean software install check the Factory Setting File [3] then Select "Download All Files" [2].
For Configuration Files Update select the "Download All Files" [2].
 Note: Add a .Zip extension to the downloaded file.
Look at the structure of the unzipped folder. The files in the folder must have an exact structure so that the machine control can find the files.
If you have (2) folders named with the machine’s serial number [2], copy the SECOND folder to the root of the USB memory device.
If you have only (1) folder named with the machine’s serial number [1], copy that folder to the root of the USB memory device.
When you are finished, the USB folder structure must look like the picture on the left. The order of the files in the CONFIGURATION folder does not matter.
Software Update
Insert the USB memory device into the USB port on the Control pendant.
The USB memory device must contain the following in the root folder:
  • Configuration files folder [1]
  • HaasUpdateData folder [2]
  • Machine backup file [3]
  • Your HaasKey.txt file [4]
Power off the machine.
Press [POWER ON] while you press and hold the [U] button until the (4) linux penguins show.
The HAAS AUTOMATION SOFTWARE UPDATER screen appears.
Press [2] to begin the Software Update process.
The UPDATE SOFTWARE FROM USB screen appears.
This screen shows the Platform Update Version and Release Notes.
Press [ENTER] to continue.
Press [M] for MACHINE.
Press [1] key for Mill or [2] for Lathe Videos.
The software update process will begin.
When the software update process is finished you will be prompted to cycle power.
Power off and power on the machine.
Go to the Haas Portal.
Use the Machine Software Update option to get the activation code.
Enter all the machine information.
Use the Machine Generated Code on the control to get the activation code.
Enter the activation code in the control and press [ENTER].
If you updated to software version 100.16.000.1030 or higher, make sure Media Display shows it has been purchased in theFeatures tab, in the Parameters tab. If it does not show that it has been purchased, load the configuration files again.
Media Display is a standard feature on all NGC machines with software version 100.16.000.1030 or higher.
Press [DIAGNOSTIC] to access the Parameters, Diagnostics and Maintenance screen.
Select the System tab.
Verify the System Platform Version [1] and Software version [2] are correct.
Configuration File Load
 Important: Make sure machine is in Service Mode. (DEBUG mode).
Insert the USB device to the control. The USB memory device must contain these items:
  • Your HaasKey.txt file [1]
  • Configuration files folder [2]
Press [EMERGENCY STOP].
Press [List Program].
Select the directory with the serial number file name [2].
Press [ENTER] to put a Mark [3] in the box for the file name [2].
Press [F4] [1].
Select Load Parameters [2].
Press [ENTER].
 Important: This starts the parameter file installation. When done do not turn off the machine.
Wait until control finish load the configuration files.
Note: If an error is generated during this process, generate an error report (SHIFT+F3) and notify the Haas service department.
Machine and Options Verification
Verify machine operation:
  • Make sure that the customer's rotary configurations are correct. Refer to: NGC- EC-1600, UMC-750 Rotary Parameter Identification
  • If the machine is equipped with a pallet pool option refer to the Enable Pallet Pool section of the installation procedure:
    EC-400 Pallet Pool Installation
    UMC-1000 Pallet Pool Installation
  • Restore the Pallet Schedule Table information
  • Make sure the pocket table is correct
  • Make sure the work / tool offsets loaded
  • Zero Return All Axes
  • Test the tool changer
  • Test the spindle RPM
  • Test coolant operation
  • Test the chip auger
  • Calibrate the probe. Refer to: Next Generation Control - Probe Calibration (VPS)
  • Test the remote jog handle
 Important: When this procedure is completed , make sure that the correct optional functions are enabled.
 Important: After you complete work on the machine, make sure you remove your Haas Control Key.
 Note: For all SS machines, you must set the T-Axis Grid Offset when you update software from 100.15.xxx.xxxx to 100.16.xxx.xxxx. Refer to Next Generation Control - Servo-Driven SMTC - Grid Offset and Tool Changer Offset.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
