  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Threading Toolholders
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Standard Coolant - Washdown Hose - Installation - VMC - AD0104
Service How To Procedures Standard Coolant - Washdown Hose - Installation - VMC - AD0104
Recently Updated Last updated: 02/15/2021
AD0104
Applies to machines built from: November, 2013
This procedure tells you how to install a washdown hose. The kit for the washdown hose is in the tote kit.
Mills larger than the VF-5 have a second washdown hose. To install a second washdown hose use this procedure: Supplemental Washdown Hose
These instructions apply to these machines:
  • VM-1/2 - Made after 11/13/2013
  • VF-1/2 - Made after 11/13/2013
  • VF-3/4/5 - Made after 02/20/2014
  • VF-6/7/8/9/10/11/12 - Made after 06/09/2014
  • DT-1 - Made after 06/09/2014
  • DM-1 - Made after 01/01/2015
  • MM/SMM - Made after 07/01/2015
Parts Required
58-1650A
QTY: 1
HOSE 3/8 ID 3/4 GHM 3/4 GHF 13.5FT
59-6310A
QTY: 1
WASHGUN, WASHDOWN GILMOUR 573
30-11613
QTY: 1
WASHGUN, HOLSTER AND GASK
40-1981
QTY: 3
FBHCS 1/4-20 X 1/2 LOCTITE
Tools Required
Crescent Wrench
5/32" Allen Wrench
Apply thread sealant to all threaded surfaces of the coolant fittings.
Find the cap [1] at the bottom left on the enclosure. Remove the cap [1] from the MALE ENCLOSURE FITTING [2].
 Note: Coolant can come out when you remove the cap.
Attach the WASH GUN HOLSTER and GASKET [E] to the enclosure face. Use the screws [F].
Attach the HOSE ASSEMBLY [C] to the MALE ENCLOSURE FITTING [2]. Attach the HOSE ASSEMBLY [C] to the WASH GUN [D].
Put the HOSE ASSEMBLY [C] in the WASH GUN HOLSTER [E].
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
