  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    3. Español
    13. Русский
Search
Option - Activation Code Only - NGC
Service Home How To Procedures Option - Activation Code Only - NGC
Recently Updated Last updated: 11/09/2021
Applies to machines built from: July, 2015
- Jump to Section - 1. NGC - Options Table 2. Option Activation Code (3 steps) Back to Top
NGC - Options Table
The options in the table require you to load a patch, enter an activation code, or both to operate correctly.
For options that require the activation code + patch files, refer to Option - Activation  Code + Patch - NGC.
 Note: Patch file names may change over time. Use the patch file from the NGC-Configuration generator on the portal. Verify by description.
Option Activation Code? Patch? Factory Setting
DC Autodoor No Yes 823 [823:]
4th-Axis Drive (4AXD) Yes No No
5th-Axis Drive (5AXD) Yes No No
Automatic Pallet Changer Ready (APC-READY) Yes No No
Chip Auger (AUGER) No Yes 209.03 [209:3]
Multi-Auger Chip Conveyor (MACC) No Yes 209.03 [209.3]
Intuitive Probing System (WIPS-R) Yes Yes No
Through-Spindle Coolant (TSC) Yes Yes 209.24 [209:24]
Enclosure Exhaust (ENCL EXHAUST) No Yes No
Programmable Coolant (P-COOL) No No  57.11 [57:11]
Through-Tool Air Blast (TAB) No Yes No
Expanded Memory, 32GB (32GB) Yes No No
Expanded Memory, 64GB (64GB) Yes No No
Coordinate Rotation and Scaling (COORD) Yes No No
Dynamic Work Offsets and Tool (DWO/TCPC)
Note:  Setting 64 Tool Offset Measure uses Work Coord Offsets needs to be toggeld ON when this option is enable.
Yes No No
Second Home Position (HOME) No Yes No
High-Speed Machining (HSM) Yes No No
User-Definable Macros (MACRO) Yes No No
Rigid Tapping (RTAP-3) Yes No No
Spindle Orientation (SO) Yes No No
Visual Programming System (VPS) Yes No No
Wireless Networking (WIFI) Yes No No
Spindle RPM Upgrade Yes No No
3RD Party Rotary (3RD PRTY RTY) Yes No No
Automatic Vise No Yes No
Mist Condenser No Yes No
Programmable Air Option No Yes No
CL-1 C-Axis Only Yes Yes No
Parameter Unlock Options - NGC Yes No No
Log on to the Haas Portal.
 Note: Be sure to deactivate the pop-up blocker.
Select the Service tab [1].
Select Machine Activation Codes [2].
Select NGC - Configuration [3].
Enter the machine serial number.
Select Get Details [4].
Select Download Files [5] of the Field Installed Option.
 Note: This example shows the 93-2389 4TH-AXIS DRIVE, NGC field installed option. Your field installed option can be different.
Unzip the files.
 Note: Add a .Zip extension to the downloaded file before you unzip it.
Save the file to your computer.
Open the machine serial number folder [1].
Open the OPTIONS folder [2].
Open the option part number folder [3].
Open the _amc.xml file [4]. You can open this file with Notepad.
 Note: If the folder has more files than the _amc.xml file, a service technician must install the option. Refer to Option - Activation Code + Patch - NGC.
This file has the activation code [5] to activate the option on the machine.
On the machine, push [DIAGNOSTIC].
Navigate to the Parameters tab [1].
Select the option [2] that you want to activate.
 Note: This example activates the Fourth Axis option.
Type the activation code [4] from Step 2.
Push [F4] to activate the option [3].
Repeat the procedure to activate other options.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
