  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Option - Activation Code + Patch - NGC
Service Home How To Procedures Option - Activation Code + Patch - NGC
Recently Updated Last updated: 02/02/2021
Tools Required
NOTE:  This is procedure should only be performed by a Haas certified service technician.
  • Haas Control Key
NGC - Options Table
The options in the table require you to load a patch, enter an activation code, or both to operate correctly.
For options that only require the activation code, refer to Option - Activation  Code Only - NGC.
 Note: Patch file names may change over time. Use the patch file from the NGC-Configuration generator on the portal. Verify by description.
Option Activation Code? Patch? Factory Setting
DC Autodoor No Yes 823 [823:]
4th-Axis Drive (4AXD) Yes No No
5th-Axis Drive (5AXD) Yes No No
Automatic Pallet Changer Ready (APC-READY) Yes No No
Chip Auger (AUGER) No Yes 209.03 [209:3]
Multi-Auger Chip Conveyor (MACC) No Yes 209.03 [209.3]
Intuitive Probing System (WIPS-R) Yes Yes No
Through-Spindle Coolant (TSC) Yes Yes 209.24 [209:24]
Enclosure Exhaust (ENCL EXHAUST) No Yes No
Programmable Coolant (P-COOL) No No  57.11 [57:11]
Through-Tool Air Blast (TAB) No Yes No
Expanded Memory, 32GB (32GB) Yes No No
Expanded Memory, 64GB (64GB) Yes No No
Coordinate Rotation and Scaling (COORD) Yes No No
Dynamic Work Offsets and Tool (DWO/TCPC)
Note:  Setting 64 Tool Offset Measure uses Work Coord Offsets needs to be toggeld ON when this option is enable.
Yes No No
Second Home Position (HOME) No Yes No
High-Speed Machining (HSM) Yes No No
User-Definable Macros (MACRO) Yes No No
Rigid Tapping (RTAP-3) Yes No No
Spindle Orientation (SO) Yes No No
Visual Programming System (VPS) Yes No No
Wireless Networking (WIFI) Yes No No
Spindle RPM Upgrade Yes No No
3RD Party Rotary (3RD PRTY RTY) Yes No No
Automatic Vise No Yes No
Mist Condenser No Yes No
Programmable Air Option No Yes No
CL-1 C-Axis Only Yes Yes No
Parameter Unlock Options - NGC Yes No No
NGC - Option Activation - Download
Log on to the Haas Portal.
 Note: Make sure you have pop up blocker deactivated.
Select the Service tab [1].
Select Machine Activation Codes [2].
Select NGC - Configuration [3].
Enter the machine serial number.
Select Get Details [4].
Select the Field Installed Option and select Download Files [5].
 Note: This example shows the 93-2320 TSC, 300 PSI W/AUTO CLEAN PUMP DT/DM field installed option. Your Field Installed Option can be different.
Unzip the files.
 Note: Add a .Zip extension to the downloaded file before you unzip it.
Save the file to the root folder of the USB memory device.
Look at the structure of the unzipped folder. The files in the folder must have an exact structure so that the machine control can find the files.
If you have only (1) folder named with the machine’s serial number [1], copy that folder to the root of the USB memory device.
When you are finished, the USB folder structure must look like the picture on the left. The OPTIONSfolder contains the necessary paramaters for the field installed option.
NGC - Option Activation - Load
Push [POWER OFF].
Insert the USB memory device into the USB port on the Control pendant.
The USB memory device must contain the following:
  • Your HaasKey.txt file [1]
  • Serial number folder [2]
Push [POWER ON].
Push [EMERGENCY STOP].
Push [LIST PROGRAM].
Push the [RIGHT CURSOR] arrow to select the USB tab [1].
Push the [DOWN CURSOR] arrow to highlight the directory with the serial number file name [2].
Push [ENTER] to Mark [3] the directory.
Push [F4] [1].
Push the [DOWN CURSOR] arrow to select Load Parameters [2].
Push [ENTER].
The configuration load process begins.
If you get this error after you load the parameters, push [CANCEL].
Power off and power on the machine.
The configuration load process is complete.
Test the field installed option to make sure it operates correctly.
 Important: You must always remove your Haas Control Key and power off the machine when you finish work on the machine.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
