  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    3. Español
    13. Русский
Search
Parameter Checker Program - CHC
Service Home How To Procedures Parameter Checker Program - CHC
Recently Updated Last updated: 06/14/2019
- Jump to Section - 1. Introduction 2. Download Parameter Checker From the Haas Portal (4 steps) 3. Parameter Checker Program Menu Option (1) - Display Parameter and Setting Ranges (8 steps) 4. Parameter Checker Program Menu Option (5) - Version History, Alarms, Etc. (3 steps) 5. Parameter Checker Program Menu Option (6) - Decimal to 32-bit Conversion (5 steps) 6. Parameter Checker Program Menu Option (7) - CNC Parameter and Setting Analysis (15 steps) Back to Top
This procedure tells you how to download and run the Parameter Checker program. Note that the examples in this procedure show the Windows 7 operating system.
The items below list different types of software and their paths on the Haas Portal:
  1. Mill Control Software : Service > Documents and Software > Control Software > Mill > Mill XXX > XXX.zip
  2. Lathe Control Software: Service > Documents and Software > Control Software > Lathe > Lathe XXX > XXX.zip
  3. Enet Firmware version 14.007: Service > Documents and Software > Control Software > Enet Firmware ("Floppy Version") > 14.007 > XXX.zip
  4. Enet Firmware version 14.011: Service > Documents and Software > Control Software > Enet Firmware ("Floppy Version") > 14.011 > XXX.zip
  5. Software Readme file: Service > Documents and Software > Control Software > readme Software Load.txt
  6. Software Load Assistant Guide: Service > Training > Procedure > Software Load Assistant
  7. Parameter Checker Program: Service > Documents and Software > Control Software > Parameter Program > XXX.zip
If you do not know how to download software, refer to Software Available for Download from HAAS Portal.
Log on to the Haas portal (https://portal.haascnc.com).
Note:  Access to the Haas portal  is only available to Haas technicians.
Click the Service tab [1].
Click Documents and Software [2].
Click Control Software.
Click Parameter Program [3].
Click the .zip file, for example 246.zip. [1]
Download and extract the .zip file. This example shows how to unzip the file in Windows 7.
Click Open [2].
 Note: If using the Chrome web browser, the folder will automatically be saved in the Downloads folder when you click on the .zip file.
Select the PP folder [2]. Click Extract all Files [1].
Click Browse [3]. Then select the C drive as the destination to extract the files. Click Extract [4].
If the Parameter Checker is already on the computer you will see the Confirm Folder Replace [1] prompt. Click Yes [2].
 Important: If this is the first time installing the parameter checker program move the P - Shortcut [3] to your desktop. Open the P- shortcut properties and make sure the fields below are set correctly:
  • Target: C:\PP\P.BAT
  • Start in: C:\PP
Use this shortcut to open the Parameter Checker.
The screen shows the Haas Automation Software Information Menu.
Press [1] to select Display parameter and setting ranges.
Use the arrow and select the software version.
Press [ENTER].
At the next menu, use the up and down arrows to select Parameters.
Press [ENTER].
If the parameter number is known, type it and press [ENTER]. For this example, 57 will be entered.
Use the arrows and select the correct feature and press [ENTER]. For this example, REVERSE CRANK DIR will be used.
Click on a line to view the basic values and an explanation of the bit.
If the parameter number is unknown, type a keyword(s) and press [ENTER]. For this example, Tool Changer will be entered.
Use the up and down arrows to view the explanation and basic values of the machine model.
 Note: If more information is needed, refer to the HAAS service manual.
The screen shows the Haas Automation Software Information Menu. Press [5] to selectVersion history, alarms, etc.
Click the Search in box and search by software type and software version . In this example, Mill and Lathe and 1804A will be used.
 Note: You can search by keyword under the Search For window.
Information on each software version can be viewed here.
The screen shows the Haas Automation Software Information Menu. Press [6] to select Decimal to 32 bit conversion.
 Note: The page will be opened in a web browser.
From the web browser, click Decimal to Hex.
Enter both decimal numbers in each text field.
Press the [=] button.
The bit information can now be viewed.
Put a USB memory device into the USB port on the control pendant.
Push [LIST PROG].
Select the USB DEVICE tab.
Push [WRITE/ENTER].
Push [F4] to open the SAVE AND LOAD menu.
Use the cursor arrows to select Save All - Back Up.
Type the machine serial number.
Push [WRITE/ENTER].
This saves a copy of the machine data files to the USB memory device.
 Note: This saves each file with the same serial number from the step before. Example: 123456.XXX.
Disconnect the USB memory device from the control.
Connect the USB memory device to your computer.
If you did not download the Parameter Checker, refer to Software Available for Download from HAAS Portal.
Open the . exe file for the Parameter Checker that you downloaded from the Haas Portal. This installs the Parameter checker program and puts a shortcut on you desktop. Open the shortcut Parameter Checker.exe file to start the program.
The screen shows Software Shipping Instructions for Production for lathes or mills.
Push any key to continue.
Push [7] to select Parameter and setting analyzer.
Push [ENTER] to clear the information screen.
Use the arrow keys to select the letter of the USB memory device. In this example, the device is E.
Push [ENTER].
Select the parameter file *.par from the list.
Push [ENTER].
Select the setting file *.set from the list.
Push [ENTER].
Select the installed machine options from the list.
Use the up and down arrow keys to go to an option and the left and right keys to select and deselect options.
Push [ENTER] when all installed options are selected.
Select the applicable report type.
Select Compare to Haas factory-set values to compare the machine parameters to factory-set values.
13
 Note: The item Compare To DEBUG Initialized Valves (For R&D Use) is for Haas engineers use only.
14
Select the Standard parameter/setting list to view a list of the parameters and settings.
Once the desired report is selected, push [ENTER].
Use the up and down arrows and page up and page down keys to scroll through the report.
Push [W] to open the report as a WordPad document for easier review and printing.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
