    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Fixture Clamps
      • Toolmakers Vise
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Plug & Ring Gauges
      • Gauge Blocks & Accessories
      • Pin Gauges & Accessories
      • Test Bars
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Parameter Unlock Option - NGC
Service Home How To Procedures Parameter Unlock Option - NGC
Recently Updated Last updated: 12/03/2021
- Jump to Section - 1. Introduction 2. Service Level 1 and 2 Comparison Chart Back to Top
Important: Machine software version needs to be 100.19.000.1200 or higher.
The Service mode option (Service Level 1 or 2) is assigned to a specific serial number.  This option is sold at the discretion of the Haas Factory Outlet.  This option will allow you to put the machine in service mode, which will allow access to the Factory, I/O Config tabs (see Service Leve1 and 2 Comparison Chart below).
Note: After you purchase this option you will need to get a activation code and a USB service key from your local Haas Factory Outlet.
Note: Once this feature is activated the Service USB key will never expire on this machine.
Function Access Function Description
Level 1
(93-3008)
Level 2
(93-2905)
Factory Tab This Factory tab is located in the Diagnostics> Parameters.  Here you will find a list of common Factory settings, like Tool Change Offsets,  Spindle Orient Offsets,  Grid Offsets, Autodoor Open Times, Disable Axes, Min/Max Coolant Level, Status Relays, Enable/Disable Chip Conveyor, Enable/Disable Coolant Spigot. X X
I/O Config Tab The I/O Config tab is located in Diagnostics.  On this tab you can Update the I/O Config Table,  when a new I/O PCB is replaced.   X X
Patches Tab This tab is located in Diagnostics>Patches.  Here you can view / install / uninstall patches.  These patches are used when adding field install options, like autodoor, mist condenser. X X
Patches Tab Generate patches.  Note: These patches will not be applied after a clean software update, they would need to be re-generated  N/A X
Configuration Tab The configuration tab contains all the machine parameters.  Here you can view parameter descriptions and change parameter configurations.   Note:  Changing parameters can cause unexpected machine behavior and can void your machine warranty. N/A X
 NOTE:  The activation procedure should only be performed by a Haas certified service technician.
If you are a technician goto the HBC Site and download the activation procedure.
Note: The activation procedure can be found on the Haas Portal under Service>Documents and Software> 10_Service Tools> Activation Parameter Unlock Option - NGC
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
