  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    3. Español
    13. Русский
Search
Software Available for Download from Haas Portal
Service Home How To Procedures Software Available for Download from Haas Portal
Recently Updated Last updated: 02/25/2020
- Jump to Section - 1. Introduction 2. Download Software From the Haas Portal (3 steps) Back to Top
NOTE:  This is procedure should only be performed by a Haas certified service technician.
This procedure lists the software programs available for download from the Haas Portal.
The items below list different types of software and their paths on the Haas Portal:
  1. Mill Control Software : Service > Documents and Software> Control Software> Mill > Mill XXX > XXX.zip
  2. Lathe Control Software: Service > Documents and Software > Control Software> Lathe > Lathe XXX > XXX.zip
  3. Enet Firmware version 14.007: Service > Documents and Software > Control Software > Enet Firmware ("Floppy Version") > 14.007 > XXX.zip
  4. Enet Firmware version 14.011: Service > Documents and Software > Control Software > Enet Firmware ("Floppy Version") > 14.011 > XXX.zip
  5. Software Readme file: Service > Documents and Software > Control Software> readme Software Load.txt
  6. Software Load Assistant Guide: Service > Training> Procedure > Software Load Assistant
  7. Parameter Checker Program: Service> Documents and Software > Control Software > Parameter Program > XXX.zip
 Note that the examples in this procedure show the Windows 7 operating system.
Log on to the Haas portal (https://portal.haascnc.com).
Click the Service tab [1].
Click Documents and Software [2].
Click Control Software.
Click Mill [3] or Lathe [3].
 Note: For this example, select Mill.
Select the software version [1].
Click the .zip file, for example Mil1810C.zip [2].
Download and extract the .zip file. This example shows how to unzip the file in Windows 7.
Click Open [3].
 Note: If using the Chrome web browser, the folder will automatically be saved in the Downloads folder when you click on the .zip file.
Insert a USB memory device into your computer. Remove all files from the USB memory device.
Click Extract all Files [1].
 Note: Make sure you extract the files to the USB memory device root directory.
Click Browse [3]. Then select a destination to extract the files. For this example, the files will be extracted to a USB memory device.
Browse to the USB Memory Device location [1] and click Extract [4].
Make sure the correct software is on the USB memory device. Write down the filename for the main .bin file, for example, M1810C.bin [2].
Enter this filename when you install the software.
Safely remove the USB memory device.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
