  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Haas Liquid Grease - Axis Lubrication System
Service How To Procedures Haas Liquid Grease - Axis Lubrication System
Recently Updated Last updated: 02/10/2021
 Note: The location of the grease reservoir is different on some machines.
The CALM - Haas Liquid Grease (HLG) lubrication system is a restrictor grease flow system that pumps grease through flexible plastic tubing and copper tubes to the axes.
Identification
 Note: For recommended lubricant types, see Lubricant Table for Haas Machine Components.
Use the illustration to identify the parts of the lubrication system.
  1. Grease Pressure Switch - Monitors the grease system pressure and sends a signal to the control to generate an alarm if the pressure drops below the minimum level too quickly.
  2. Grease Pressure Gauge - Shows the pressure (in psi and bar) of the grease system.
  3. Grease Filter Wrench - Removes the grease reservoir.
  4. Grease Reservoir Assembly - Stores the grease.
  5. Air-Lube Panel Decal - Shows the color-coded cables that connect each solenoid.
  6. Oil Reservoir - Stores the oil that lubricates the spindle.
  7. Air Manifold Assembly - Supplies air to the machine.
  8. Axis-Lube Air Solenoid - Pressurizes the grease reservoir.
  9. Air Pressure Gauge - Shows the pressure (in psi and bar) at which the air is supplied.
  10. Electronic Analog Air Pressure Sensor - Monitors the air system pressure and sends a signal to the control to generate an alarm if the pressure drops below the minimum level for a set period of time.
Axis Lubrication
The grease reservoir [1] lubricates the axes at a rate of (1) grease cycle for every 24 hours of axis travel.
  • Grease moves from the grease reservoir [1] through flexible plastic tubing [2] to the axis manifolds [3].
    • The number of axis manifolds may be different on some machines.
    • Each axis has (1) ballnut [4] and (4-6 ) linear guide trucks [5].
  • Grease moves from the axis manifolds [3] through copper tubes. The copper tubes lubricate the ballnuts [4] and the linear guide trucks [5].
    • There is (1) copper tube that goes to the ballnut and (1) copper tube that goes to each linear guide truck.
The Haas Liquid Grease canister lasts approximately 10 months to a year under normal machine operation, 8 hours a day and 5 days per week.
Axis Manifold Fitting Information
The Haas Liquid Grease lubrication system uses adapter fittings [1] in the axis manifolds. The linear guide trucks and ballnuts use restrictor fittings [2]. The restrictor fitting has a gap [4] between the threads and the set screw [3]. This forces the manifold-fed grease to pass through the gap [4] to lubricate the axes.
 Note: The copper tubes on this system may or may not be equal length.
 Caution: Do not change the length of the copper tubes or flexible plastic tubing. This changes the flow of grease.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
