  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Umbrella Tool Changer - Set Parameter 257 - Spindle Orientation Offset - CHC
Service How To Procedures Umbrella Tool Changer - Set Parameter 257 - Spindle Orientation Offset - CHC
Recently Updated Last updated: 11/29/2018
Applies to machines built from: June 1997
- Jump to Section - 1. Umbrella Tool Changer - Set Parameter 257 - Spindle Orientation Offset (4 steps) 2. Umbrella Tool Changer - Set Parameter 257 - Spindle Orientation Offset - Service (4 steps) Back to Top
If the machine has a gearbox, operate this code in MDI mode:
M41;
This puts the machine in low gear and makes the spindle easier to turn with your hand.
Make sure no tool is in the spindle. Make sure no tool is in the pocket that faces the spindle.
Push [EMERGENCY STOP].
Go into DEBUG mode
Push [POSIT].
Select the VAR tab [1].
 Note: If you have software version 15.xx or earlier, navigate to the VAR tab.
Push [WRITE/ENTER]
Select the RAW DATA tab [2].
Turn the spindle dogs with your hand. Turn until the SPINDLE POS [3] value is between 0 and 2000. Make the value as near as possible to 0.
Attach the spindle lock tool (T-1635). This tool aligns the spindle dogs.
 Caution: Make sure the SPINDLE POS value stays between 0 and 2000. If the value is not accurate, you will crash the machine.
Enter the SPINDLE POS value into Parameter 257.
Exit DEBUG mode.
Remove the Spindle Lock Tool (T-1635).
Test the spindle orientation:
  1. Put a tool in the spindle.
  2. Go to MDI mode.
  3. Push [ATC FWD].
  4. Push [ATC REV].
Make sure the machine has a smooth tool change.
If the machine does not does not have a smooth tool change, the machine has (1) of these conditions:
  • The spindle orientation was not done correctly. You must repeat the procedure.
  • An umbrella tool changer alignment is necessary. Refer to VMC - Umbrella Tool Changer to Spindle - Alignment.
This procedure tells you how to set Parameter 257 (Spindle Orientation Offset) on a machine that has an umbrella tool changer.
This procedure is only for service technicians. For customers, use the procedure above which does not go into debug mode.
Tools Required
  • Spindle Lock Tool T-1635
M41;
Go into DEBUG mode
Push [POSIT].
 Note: If you have software version 15.xx or earlier, push [PAGE UP] or [PAGE DOWN] to go to the VAR tab.
Push [WRITE/ENTER].
Exit DEBUG mode.
  2. Go to MDI mode.
  3. Push [ATC FWD].
  4. Push [ATC REV].
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
