  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Side-Mount Tool Changer - Set Parameter 257 - Spindle Orientation Offset - CHC
Service How To Procedures Side-Mount Tool Changer - Set Parameter 257 - Spindle Orientation Offset - CHC
Recently Updated Last updated: 11/30/2018
Side-Mount Tool Changer - Set Parameter 257 - Spindle Orientation Offset - Classic Haas Control (CHC)
Applies to machines built from July, 1998
- Jump to Section - 1. Side-Mount Tool Changer - Set Parameter 257 - Spindle Orientation Offset (4 steps) 2. Example Table 3. Side-Mount Tool Changer - Set Parameter 257 - Spindle Orientation Offset - Service (3 steps) Back to Top
How to align the spindle dogs parallel to the X Axis without a dial indicator:
  1. Push [ORIENT SPINDLE]. Push [EMERGENCY STOP].
  2. Push [SETTING]. Set Setting 7 to OFF.
  3. Push [PARAMETER/DIAGNOSTIC]. Go to Parameter 257.
  4. Increase the value of Parameter 257 in increments until the spindle dogs are parallel to the x axis after you push [ORIENT SPINDLE].
 Note: If you add 1000 to the value of Parameter 257, this equals approximately 1/4 turn of the spindle orientation location.
          5. Release [EMERGECY STOP]. Push [RESET].
          6. Align spindle dogs parallel to X-axis. Push [ORIENT SPINDLE].
Put the magnetic base with the indicator on the table.
Handle jog the machine to indicate the alignment of the spindle dogs and the X Axis.
The spindle dogs must be aligned within 0.010" (0.254 mm) of the X Axis.
Perform STEP 1 instructions again until the spindle dogs align with the X Axis. Make sure the alignment error is not more than 0.010" (0.254 mm) of the X Axis. Increase or decrease the value of Parameter 257 by much smaller increments.
 Caution: After you change the value of Parameter 257, make sure the indicator is out of the path of the spindle dogs.
Determine the correct value for Parameter 257:
Divide the value of Parameter 79 by 360. This tells you the number of encoder counts per degree of spindle rotation.
Example: Parameter 79 = 4096 ; 4096 / 360 = 11.37
Multiply the number of encoder counts per degree of spindle rotation by the correct value for your machine: 30-Taper = 88.6; 40-Taper = 74; 50-Taper = 66.6. Round the result to the closest whole number. Subtract the rounded number from Parameter 257. Refer to examples in the table below.
Operate a tool change with no tools in the spindle or pocket.
Push [FEED HOLD] when the tool changer arm is at the spindle. Make sure the spindle dog [1] is aligned to the key [2] on the tool changer arm.
 Note: To make a fine adjustment to Parameter 257, push [CYCLE START] to complete the tool change. Increase or decrease the value of Parameter 257 in increments of 10 until the spindle dogs are aligned.  Repeat this step if necessary.
Push [SETTING]. Set Setting 7 to ON.
Example Table
Taper Multiply encoder counts per degree of spindle rotation by the correct value for your machine Round to the closest whole number Subtract from Parameter 257
30‑Taper 11.37 * 88.6 = 1007.382 1007 1892 - 1007 = 885
40‑Taper 11.37 * 74 = 841.38 841 1892 - 841 = 1051
50‑Taper 11.37 * 66.6 = 757.242 757 1892 - 757 = 1135
Press [ZERO RETURN], [ALL], and [HOME G28], in that order.
Enter DEBUG mode and TOOL CHANGER RECOVERY mode.
Press [ATC FWD] to move the double arm [3] toward the spindle dogs [1].
Make sure that there is enough clearance to turn the spindle dogs.
 Note: If your spindle has a spindle dog [2] longer than the other, make sure it is turned away from the double arm. The long spindle dog has a hole on the bottom.
Press [POSIT].
Select the VAR tab and then select the RAW DATA tab.
Turn the spindle dogs with your hand until the value of SPINDLE POS is near 0 and not a negative number. Align the spindle dogs with the slot in the arm.
Enter TOOL CHANGER RECOVERY mode.
Press [ATC FWD] until ARM at CL/UNCL has a value of 1.
Turn spindle dogs [1] until the spindle dog touches the shoulder [2].
Record the number shown in SPINDLE POS.
Turn until the spindle dog touches the other shoulder.
Add the value of the two spindle positions. Divide the sum by 2.
Example: 1401 + 101 = 1502. 1502/2 = 751
Enter the new value into parameter 257.
Press [ATC FWD] until ARM at CL/UNCL is 1.
Press [ATC REV] until the screen shows the Arm At Origin and/ or message [1].
Press [Orient Spindle], then press [O].
Press [ATC FWD] repeatedly to verify alignment.
Press [ATC REV] until the screen shows the Arm At Orgin and/ or message [1].
Exit TOOL CHANGER RECOVERY mode and DEBUG mode.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
