  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
UMC-1000 C-Axis Removal - AD0474
Service How To Procedures UMC-1000 C-Axis Removal - AD0474
Recently Updated Last updated: 11/10/2020
UMC-1000 C-Axis - Removal
AD0474
- Jump to Section - 1. Removal Process (15 steps) Back to Top
Removal Process
Disable the C-Axis by changing parameter 7.004 to 1.
Remove the bottom cover from the C-Axis. Then, unwire the C-Axis servo motor and the scale.
Remove the 4 bolts that attach the C-Axis body to the B-Axis platter. (See Image)
Remove these 4 bolts.
Install the T-2194A lfiting aid.
Remove the A-Frame support bolts and shims. Remove the A-Frame support.
Use the eye bolt installed on T-2194A to hoist the C-Axis with a forklift or crane.
Remove the remaining bolts that attach the C-Axis body to the B-Axis platter. (See Image)
Remove the C-Axis assembly from the machine.
Now that the C-Axis is out of the way, check the runout of the B-Axis center bore. Record this reading.
Make sure the brake booster is disconnected from the rotary before continuing. If the brake is pressurized with the platter removed, it will become damaged beyond recovery.
Remove the platter.
13
Inspect the brake surfaces.
14
Remove the 10 bolts shown. (See Image)
Then, remove and replace the B-Axis brake if needed.
Verify the platter bore ID is within print specification.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
