  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Vertical Axis - Servo motor - Replacement
Service How To Procedures Vertical Axis - Servo motor - Replacement
Recently Updated Last updated: 11/28/2018
Vertical axis - Servo motor - Replacement
- Jump to Section - 1. Introduction 2. Tools Required 3.  Replace the servo motor (4 steps) Back to Top
This procedure tells you how to replace the servo motor on the vertical axis. This procedure applicable for HMC Y axis, VMC Z axis and Lathe X axis that is NOT equipped with the counterbalance system and has a solid coupling. Refer to the Ballscrew - Flex Coupling - Replacement if your machine has the flex coupling.
Warning: You should not do machine repairs or service procedures unless you are qualified and knowledgeable about the processes. Serious damage to the machine components can result in costly repairs. The service technicians at your Haas Factory Outlet (HFO) have the training and experience, and are certified to do these tasks safely and correctly. The repair and service work performed by your HFO is protected with a limited warranty.
Tools Required
  • Tooling for blocking the spindle head: T-0098 (MiniMill), T-0099 (Sm, Med, Lg VF's), or T-0100 (TM)
Remove all of the sheet metal parts that obstruct the access to the servo motor housing.
Remove the coupler access cover [1] from the servo motor housing.
Block the spindle head with a wooden block or the spindle head support tooling at the height that allows the access to the lower coupler clamping bolt [2].
Important: Slowly jog the spindle head onto the spindle head support until it is making full contact so that it does not drop onto the support when you turn OFF the servo motors.
Power the machine OFF.
Loosen the lower coupler clamping bolt [1].
Warning: If the spindle head is not properly blocked for the next step it could drop and cause damage to the machine or yourself. Verify that the spindle head is securely blocked before disconnecting power to the servo motor and brake.
Disconnect the power, brake, and encoder cable from the motor.
Remove the bolts [2] that secure the servo motor to the housing.
Note: Be aware that when removing the last bolt, the servo motor may tend to turn as the weight of the spindle head is transferred to the wooden block.
Note the orientation of the cable connectors.
Lift the servo motor straight up, as square as possible to the housing, until the coupler disengages the end of the ballscrew and remove it from the machine.
Loosen the upper coupler clamping bolt [3] and remove the coupler from the motor.
Note: Make sure you retain the shaft key from the ballscrew [4] and the servo motor shaft [5].
Note the orientation of the servo motor shaft.
Important: When installing the coupler and the servo motor make sure that the shaft keys are in place during the process. It is possible for the key to fall out during installation. Missing key will result in positioning accuracy errors.
Connect the power, brake and the encoder cables to the motor.
Power ON the machine.
Change setting [53 - JOG W/O ZERO RETURN] to ON.
Hand jog the vertical axis until orientation of the new servo motor shaft matches the orientation of the old servo motor shaft.
Turn the machine OFF.
Install the shaft key [1] in the keyway on the end of the ballscrew.
Install the coupler [2] on the end of the ballscrew.
Note: Leave the clamping bolt loose at this time.
Orient the motor so the cable connectors are facing the same direction as the old servo motor.
Align the key [3] on the servo motor shaft with the keyway in the coupler and lower the servo motor onto the housing.
Install the servo motor mounting bolts [4] and torque them.
Center the coupler [5] between the ballscrew and the servo motor and torque the clamping bolts [6].
Install the coupler access cover [7].
  • Reset the axis grid offset. Refer to the Axis Grid Offset - Mill 13.14 or Higher and Lathe 6.11 or Higher for CHC and Next Generation Control - Axis Grid Offset for the NGC.
  • Reset the axis tool change offset. Refer to VMC - Side-Mount Tool Changer - Z-Axis Tool Change Offset, Umbrella Tool Changer - Set Parameter 64 - Z-Axis Tool Change Offset for the CHC and the Next Generation Control - Side-Mount Tool Changer - Z-Axis Tool Change Offset, Next Generation Control - Umbrella Tool Changer - Z-Axis Tool Change Offset for the NGC.
  • Refer to the Haas Fastener Torque Specifications for the torque values.
  • For the ballscrew specific tooling and torque values refer to the Ballscrew - Installation Tools and Torque Specifications.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
