    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Fixture Clamps
      • Toolmakers Vise
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Plug & Ring Gauges
      • Gauge Blocks & Accessories
      • Pin Gauges & Accessories
      • Test Bars
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Main Software and Communications Firmware ("Floppy Version") Compatibility Table - CHC
Recently Updated Last updated: 08/10/2018
To make sure the machine operates correctly, install the correct communications firmware ("Floppy Version") with the correct main software version.
This table shows the main software versions with the correct communications firmware versions.
Stack Configuration Mill Software Lathe Software Communications Firmware
68K PCB + PC104 PCB 13.06 - 13.18 6.06 - 6.14 11.004 (not field upgradable)
68K PCB + PC104 PCB 13.06 - 13.18 6.06 - 6.14 12.001 - 13.009
CF1 PCB + PC104 PCB 14.00 - 14.05 7.00 - 7.04 11.004 (not field upgradable)
CF1 PCB + PC104 PCB 14.00 - 14.05 7.00 - 7.04 12.001 - 13.009
CF2 PCB with 8MB Flash 15.00 - 15.06 8.00 - 8.06 9.015 (not field upgradable)
CF2 PCB with 16MB Flash 16.00 - 16.11 9.00 - 9.11 9.015 (not field upgradable)
CF2 PCB with 8MB Flash + PC104 PCB 15.00 - 15.06 8.00 - 8.06 11.004 (not field upgradable)
CF2 PCB with 8MB Flash + PC104 PCB 15.00 - 15.06 8.00 - 8.06 12.001 - 13.009
CF2 PCB with 16MB Flash + PC104 PCB 16.00 - 16.11 9.00 - 9.11 13.001 - 13.009
Maincon PCB 17.00 - 18.10 10.00 - 11.07 14.001 - 14.011*see note
Maincon PCB 18.11 - 18.29 11.08 - 11.27 14.011
 Caution: Do not install communications firmware versions 12.xxx over versions 11.xxx, and do not install communications firmware versions 14.xxx over versions 13.xxx or lower. This will damage the Enet PCB and the CNC machine will not operate correctly.
 Note: To upgrade communications firmware 14.005 or lower to 14.011 you must upgrade to 14.007 first and then to 14.011.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
