  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Threading Toolholders
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
BMT Live Tooling Troubleshooting Guide
Service BMT Live Tooling Troubleshooting Guide
Recently Updated Last updated: 02/17/2020
- Jump to Cause - 1. Introduction 2. Symptom Table 3. Amplifier Short Circuit Inspection 4. Servo Motor Short Circuit Inspection 5. Drive Alignment 6. Vibration Analyzer Back to Top
100% duty cycle at 4500 RPM.
15% duty cycle at 6000 RPM.
Live Tooling Alarms 11.993, 11.103, and 11.9959 The servo motor has a fault Refer to the Sigma 5 Servo Motor Troubleshooting Guide.
The amplifier has a fault.
Refer to the Amplifier Troubleshooting Guide.
Note: If a short-circuit is found, inspect the cable and motor for a short circuit before installing a new amplifier.
Noise/Vibration The drive is out of alignment. Re-align the live tooling drive.
A drive bearing has failed. Perform a Vibe Test.
Check the amplifier for a short. Power off the machine. Disconnect the cables for the axis servo motor at the amplifier that generates the alarm.
Place MultiMeter Leads Here Instructions
Set the meter to ohms, and take the following readings:
Ground screw to RED, WHT, and BLK terminals
If the meter does not show open (o.l) the amplifier is damaged.
Set the meter to Ohms, and take the following readings:
Black lead on HV (+) and Red lead to HV (-), RED, WHT, and BLK terminals
If the meter does not show mega ohms or higher the amplifier is damaged.
Set the meter to diode test mode, and take the following readings:
Red lead on HV (-) and black lead to HV (+), RED, WHT, and BLK terminals
If the meter does not show a voltage drop ranging from 0.2 to 0.8 volts the amplifier is damaged.
Black lead on HV (-) and red lead to HV (+), RED, WHT, and BLK terminals
If the meter does not show an open circuit (O.L) the amplifier is damaged.
Corrective Action:
Check the cables for a short: Make sure the axis servo motor cables are not contaminated or pinched. Contaminated or pinched cables can cause a short. Replace the cables if necessary.
Inspect the servo motor. Disconnect and inspect the power cable connector at the motor. Make sure that there is no coolant contamination. Coolant contamination can cause this alarm and damage the amplifier. Measure the resistance from the pins labeled A, B and C at the motor connector to chassis ground.
  • The reading should show an open circuit.
  • If there is not open resistance, the servo motor is at fault.
Drive Alignment
Run the live tooling without a driven tool in place. If the noise is gone or reduced check the live tooling drive alignment.
Follow the alignment procedure fully.
Vibration Analyzer
For a detailed procedure see BMT Live Drive Turret Vibration Test
Install an empty live tool holder in tool #1. Install the accelerometer on the driven tool.
Set the Averages to 8.
Right click on the plot and highlight X-Axis, click on CPM.
Right click on the plot and highlight Y-Axis, click on Vibration Displacement.
Right click on the plot and highlight Y-Axis, Scaling, click on .1 mil.
Run the live tooling at 6000 RPM and start the vibe test. NTE 0.01 MIL at 6000 CPM (RPM)
If the plot is out of tolorance, re-align the drive and test again.
Use another driven tool to verify that it is not causing the issue.
Verify alignment with the correct tooling before any parts are replaced.
Possible parts that cause vibration are the bearing and live drive shaft or the servo motor and coupler.  Another cause could be a coolant leak in the turret.  Verify that no coolant is found in the turret if replacing parts.  Coolants leaks happen if there is porosity in the turret.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
