  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
NGC Software - Troubleshooting Guide
Service Home NGC Software - Troubleshooting Guide
Recently Updated Last updated: 01/13/2022
- Jump to Cause - 1. Introduction 2. Symptom Table Back to Top
Use this document to troubleshoot software issues and update problems on a machine with the Next Generation Control. If you can not find the scenario that matches your situation, please submit an error log ([SHIFT] + [F3]) to [email protected]
 Note: If necessary the error log command ([SHIFT] + [F3]) can be initiated while the program is running.
The control won't boot up or hangs at the Haas logo after a software update. The software version is not compatible with the processor installed. Check the processor part number and make sure that the correct software version was installed. See the Hardware and software Version Compatibility Table.
The software did not load correctly. Use a SanDisk Extreme USB 3.0 USB device to load the software. Reload the software using option 5) Perform Clean Software Install. Refer to: Next Generation Control - Software Update - Clean Installation.
The machine will not boot to the software updater screen when powering on and holding the U button. The machine lost power during a software update. Do not replace processor try to recover the software with the Software Update Recovery - NGC procedure.
The software files are corrupted.
The USB deviced failed during a software update.
Machines with software version prior to 100.17.000.2034. The control freezes, blank monitor, black screen, keypad not working, won't boot sometimes, random shutdowns, or software alarms. The parameters for the Q7 module on the Maincon PCB are outdated. The updated parameters have been incorporated into the software version 100.17.000.2034 (TP 21894). Update the software to the latest version. If the symptoms continue after updating the software, download the error log with [SHIFT] + [F3] and e-mail it to Haas Service Department.
Alarm 9100.021 NON RESETTABLE SOFTWARE ERROR
Alarm 9101.011 RESETTABLE SOFTWARE ERROR
The software encounter an error. Download the error log with [SHIFT] + [F3] and e-mail it to Haas Service Department.
Alarm 9972 FPGA CONFIGURATION FAULT. The FPGA software did not get loaded correctly during the software update. Use a SanDisk Extreme USB 3.0 USB device to load the software. Reload the software using option 5) Perform Clean Software Install. Refer to: Next Generation Control - Software Update - Clean Installation.
Alarm 9933 - SOFTWARE VERSION MISMATCH The configuration files loaded to the control do not match the software version on the machine. Make sure the configuration file that is being loaded matches the software version on the machine.
  1. Download the configuration file from the portal
  2. Add the .zip extension and unzip the files.
  3. open the _cv.xml file in notepad
  4. search for keyword: Software Version make sure the software version matches the software version on the machine.
If the configuration file is correct:
  • Try reloading the configuration files again. Refer to: Next Generation Control - Configuration File - Download/Load
  • If that does not work reload the software using option 5) Perform Clean Software Install. Refer to: Next Generation Control - Software Update - Clean Installation.
Alarm 9934 - INTERNAL VARIABLE NOT INITIALIZED The configuration files loaded on the control do not have all settings that the new software has. Make sure you load the latest configuration file for the software version you have on the control.
The Z Axis does not jog and can not do a tool change after a software update. Option 5 Clean Software Install was selected for software update and theserial_number.fs file in the configuration folder is missing. Make sure the Factory Settings File box is checked when you download the configuration files. Make sure theserial_number.fs file is in the configuration folder.
The software was updated to the latest version from a machine that had software version 100.16.000.1020 or lower. Load software 100.16.000.1021 first then you can upgrade to the current software version. This version is located on the portal.
Alarm 9915 - IO BOARD CONFIGURATION MISMATCH
Alarm 9100.006 - NON RESETTABLE SOFTWARE ERROR
The new configuration files were not updated before the software update.
  1. Press [POWER OFF].
  2. Put the USB memory device into the control.
    Note: The USB memory device must contain your Haas Control Key and the correct configuration files.
  3. Press [POWER ON].
  4. Press [DIAGNOSTIC].
  5. Use the arrow keys to go to I/O Config [2] in the Diagnostics tab [1].
  6. Press [F3] to Update Config Table [4].
  7. Press [RESET] to continue. If the alarm does not clear, cycle the machine power.
The Main Crc and the Factory Crc [3] are now the same.
[ERROR] appears during a software update or platform version update.
The USB is not being read.
  2. Do the software update again with a different USB memory device.
The software binary is corrupted. Re-download the software from the portal and try the update with the new files.
Machines with 100.17.000.2040 of later, during a software update you get the following USB error: "The system check detected the USB connector is inserted into the wrong port on the skbif or main board......" The USB cable on the Maincon or SKIBF PCB is connected to the wrong location. Make sure the USB cable going to the SKIBF PCB is connected to the correct location, #2, on the Maincon PCB (See above diagram).
Alarm 120 LOW AIR PRESSURE OR FLOW and inputs are not being read after software update to 100.20.000.1110 or higher. The I/O configuration file did not got loaded correctly.   Reload the software using option 5) Perform Clean Software Install. Refer to: Next Generation Control - Software Update - Clean Installation.
Alarm 9927 Motion Channel Unable To Initialize The software encountered an error.
If the machine does not have the latest sofware: Cycle power the machine, is the alarm present? If no, continue to use the machine. If yes, update the machine software to the latest.
If the machine has the latest software or alarm is generated again after updating software. Send an error report to the Haas Service Department. Cycle power the machine, is the alarm present? If no, continue to use the machine. If yes, cycle power machine until alarm is no longer present. If the alarm does not go away contact the Haas Service Department.
Alarm 9909 SPINDLES SPEED SYNCHRONIZATION ERROR Occurs when running G14 after G199 (TP#31701) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 9981 TAILSTOCK MOTION PROHIBITED gets generated when the  G28 button is pressed with the ATP in the down position. (TP#30998) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 311 UNKNOWN CODE and 339 MULTIPLE CODES is generated when running a VPS program in MDI.  The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 861 SPINDLES PHASE SYNCHRONIZATION LOST is generated when using G199 with no R code, during spindle synchronization. (TP#36107) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 10.116 LT (LIVE TOOL) Spindle Orientation Fault when pressing feed hold. (TP#34939)) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 12.108 SS (2ND SPINDLE) AXIS SERVO OVERLOAD when clamping both spindle chuck on the part hile G199 is active. (TP#37122) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 12.9126 SS (2ND SPINDLE) SPINDLE CHUCK CLAMPED when M299 is immediately preceded by clamping sub-spindle chuck command. (TP#35674) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 9996 MORE THAN ONE SPINDLE IS TURNING when the live tool spindle was stopped by an orient, subsequent canned cycles using the main spindle. (TP#36892) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 981 PALLET CHANGER INTERNAL ERROR if an axis was not at zero when a pallet change was requested.  (TP#37996) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 9100.018 JAVA RX MSG TIMEOUT (TP#42389) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 370 CANNED CYCLE GEOMETRY ERROR when the feedrate is not specified while in a G71/G72 Canned Cycle.  (TP#40690) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 174 TOOL LOAD EXCEEDED generated erronously when tool RPM i s ramping up. (TP#43268) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
Alarm 9971 EXCESSIVE AXIS SPEED OR ACCELERATION and 549 INTERNAL MOTION ERROR DETECTED with incorrect cutter compensation mode work in G112 mode. (TP#44276) The software is outdated. Update the software to the latest version.  Contact your local Haas Factory Outlet.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
