    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
    • 08-1760
      08-1760
      08-1760 View All
      • 08-1760
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Manual Chucks
      Manual Chucks Shop All
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
NGC Software Version 100.17.000.2045 Released
Service Home Service Updates NGC Software Version 100.17.000.2045 Released
June 01, 2018 - NGC Software Version 100.17.000.2045 Released
NGC software version 100.17.000.2045 has been released and is available for download from the Haas Portal. This release is for NGC Mill, Lathe and Simulators. For a complete list of corrections refer to the release notes on the Haas Portal >Service Tab> Documents and Software > Control Software > Next Generation Control > Mill, Lathe and Simulator Software.
  • In previous versions alarm 9802 SIO MCU COMMUNICATION LOSS would intermittently be generated by the control. This has been fixed in this version (TP#24753).
  • In previous version setting 340 Chuck Clamp Delay Time did not work correctly.  This has been fixed in this version. (TP#24949).
  • In software version 100.17.00.2020 and later, if a machine was configured to have more than 5 axis, the offset page did not displayed all the axes.  This has been fixed in this version (TP#24533).
This software also includes 100.17.000.2044 and lower corrections and updates:
  • In previous versions pressing the jog lock while holding the axis jogging keys would not always stop jogging.  This has been fixed in this released (TP#24035)
  • In 100.17.000.204x versions a problem affected machines with the bearingless union.  If a tool change occurred, and the TSC was not on, then the TSC vacuum would turn on and stay on after the tool change was completed.  This has been fixed in this released (TP#24596).
  • VPS Template fixes.
  • Ability was added to update the SKBIF firmware from the main software update (TP#23798).
  • In previous version there was a problem where during tool change recovery alarm 2066 TOOL CHANGER HOME POSITION FAULT would be generated.  This is fixed in this version.(TP#20948).
  • In previous version alarm 379 SKIP SIGNAL NOT FOUND would intermittently be generated.  This is fixed in this version (TP#24118).
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
