Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
    • Product Image Automation
      Automation
      Automation View All
      • Automation
      • 5% off + saving on Automation
      • VF-2SS
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • 3D Sensor Kit, Inch, CT40
      • 3D Sensor Kit, Metric, SK40/DIN
      • 3D Sensor Kit, Metric, BT40
      • 3D Sensor Kit, Inch, HSK63A
      • 3D Sensor Kit, Metric, HSK63A
      • 3D Sensor, Inch
      • 3D Sensor, Metric
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
NGC Software Version 100.18.000.1012 Released
Service Home Service Updates NGC Software Version 100.18.000.1012 Released
July 27, 2018 -NGC Software Version 100.18.000.1012 Released
NGC software version 100.18.000.1012 has been released and is available for download from the Haas Portal. This release is for NGC Mill, Lathe and Simulators. For a complete list of corrections refer to the release notes on the Haas Portal >Service Tab> Documents and Software > Control Software > Next Generation Control > Mill, Lathe and Simulator Software.
  • In previous version a intermittent 9915 IO BOARD CONFIGURATION CRC MISMATCH alarm could be generated.  This issue has been fixed in this version (TP#27340)
  • In previous version a spindle orient alarm could be generated after the C-axis engaged.  This issue has fixed in this version (TP#27385)
  • In previous versions alarm 9987 G105 PROHIBITED WITH INSIDE DIAMETER CHUCK CLAMPING was erroneously generated when using ID collet types.  This issue has been fixed in this version. (TP#27411)
  • In previous versions CL machines, alarm 9971 EXCESSIVE SPEED/ACCELERATION could be generated when the C-axis was commanded.  This issue has been fixed in this version. (TP#27432)
  • In previous versions CL machines could get stuck in a rapid state.  The issue affects lathes with the C-axis option.  Intermittently the machine would not complete tool changes, leaving it unable to complete a rapid motion.  This issue has been fixed in this version. (TP#27443)
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
