Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
Search
NGC Software Version 100.20.000.1200 Released
Service Home Service Updates NGC Software Version 100.20.000.1200 Released
December 08, 2020 NGC Software Version 100.20.000.1200 Released
 This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
NGC software version 100.20.000.1200 has been released.
Features:
  • Implement enhanced behavior of ATC buttons for machines with Pocket Tool Table (TP# 44299).
  • Graphics auto switch of plane.  When G17, G18 or G19 executed while in Graphics the display will automatically update to show you your
    actions in that plane. (TP# 45832)
  • MRZP VPS Template & Macro Update for UMC's (TP# 47004)
  • Added RJH support for multiple vises. (TP# 47382)
  • UMC-APL Added user control of APL Door to setup and recovery pages (TP# 47655)
  • Added the ability to separate the system vs motor characteristic parameters to make the Mocon design and motor replacement easier and improve productivity (TP# 47691).
  • Robot add days code to the robot unlock (TP# 48613).
  • Implemented G167, which allows users to change settings from G-code program.  (TP# 12002)
  • Template: Add G167 to MRZP Trunnion VPS Template (TP# 48877).
Corrections:
  • Allow block delete feature in G112 mode.  Block delete is now allowed in G112 mode. (TP# 23574).
  • G254 DWO and G150 Pocket Milling cause misposition.  When using G254 DWO in a G150 Pocket Milling cycle the control did not apply Dynamic Work Offsets, which caused the control to command the tool to move to incorrect positions.  This issue has been fixed in this version (TP# 35794).
  • MediaPlayer memory leak.  Fixed potential memory leak regarding repeated loading media file on the external display or rapidly enabled and disabling this feature.  (TP# 48862)
  • Hydraulic work holding unclamps if the pedal is pressed while the machine is running.  This issue has been fixed in this version (TP# 49119).
  • Performed work to improve stability of G112 algorithm to reduce occurances of erroneous 9971 alarms (TP# 44101).
  • GM-2-5AX inner swarf path is very jerky gives bad finish (TP# 47734).
  • APL Unable to get out of feedhold issue.  This issue has been fixed in this version (TP# 47979).
  • VPS - MRZP Trunnion - Alarm 503 Illegal Macro Variable when running the MDI program. This issue has been fixed in this version (TP# 48371).
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
