Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
Search
NGC Software Version 100.21.000.1132 Released
Service Home Service Updates NGC Software Version 100.21.000.1132 Released
December 07, 2021 NGC Software Version 100.21.000.1132 Released
NGC software version 100.21.000.1132 has been released.
This software version 100.21.000.1132 contains all the software fixes for 100.21.000.1131 and lower.
New Features:
  • Robot: Improve Robot Frame Management, Improve time robot stopped between motions - Improved motion frame processing to reduce pauses between motions due to unnecessary frame set commands. (TP#52429)
  • Robot Custom: .SQC file is not loaded when switching from simple to custom sequence - Updated APL job loading logic to allow loading of custom items regardless of job sequence type.  (TP#53239)
  • Parametrize "spindle cold" warmup behavior - There is now the option to use the spindle motor temperature as the value for triggering the Cold Spindle Warning popup. (TP#57149)
  • Adjust specifics of HSK spindle clamp switch signal with drawbar retry - Task that implemented drawbar retry sequence was removed as un-needed and causes undesired side-effects. Side effects were visible on some machines with HSK spindle with the software version 100.21.000.1130 and 100.21.000.1131. (TP#60576)
Corrections:
  • Misposition when running a G254 DWO program after stopping at a G234 TCPC. -  Fixed a bug that led to incorrect G254 behavior after a G234 interruption. (TP#35265)
  • Lag when switching from Z axis jog to X after cycling power, Z axis moves 2"/50mm before X kicks in. - There was an issue where jogging a non-default axis immediately after the machine is powered on may result in the original, default axis moving before the newly selected axis kicks in. This issue has been fixed. (TP#40910)
  • G103 may allow an additional block - An issue has existed on machines such that G103 would occasionally allow an extra block to be processed. This could result in a wide variety of issues, such as sporadic incorrect macro calculation. This issue has been corrected. (TP#43087)
  • Spindle Probe Breaking Stylus - Issue was introduced on mills in software version 100.21.000.1100 such that any attempt to change the active tool offset to 200 in a program would not work, leaving the active offset at the previous value. This has been corrected. (TP# 57216)
  • EC-400- G254 does not translate to the correct MRZP position. - Changed behavior of control so that G254 is respected on EC-400 whether parameter 6.342 is set to INDEPENDENT or MASTER.  (TP# 57276)
  • Changing Setting 382 does not clear shelves on Assist PP - This issue exists in the release 100.21.000.113X branch. Previously, for the Assist Type Pallet Pool, toggling Setting 382 "Disable Pallet Pool" would cause the Pallet Pool to stop working. The solution from this point is to make a service call, and get a patch to fix the configuration. Now, the issue has been corrected and Setting 382 is working as expected on the Assist Type Pallet Pool. (TP# 60312)
Important: This software version is not compatible with VMT750 and with machines that have the regen vector drive.  A machine equipped with the Regen Vector Drive will not have a Regen box, also the Regen Vector Drive is label HFD-4R.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
