  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
      • Rotary_Videos
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    3. Español
    13. Русский
Search
Patch File Load Uninstall - NGC
Service Home How To Procedures Patch File Load Uninstall - NGC
Recently Updated Last updated: 02/04/2021
Patch File Load / Uninstall - NGC
Options Table
NOTE:  This is procedure should only be performed by a Haas certified service technician.  This procedure is only for Loading and Uninstall parameter patches.
For options that only require the activation code, refer to Option - Activation  Code Only - NGC.
For options that require the activation code + parameters and I/O patch files, refer to Option - Activation  Code + Patch - NGC.
 Note: Patch file names may change over time. Use the patch file from the NGC-Configuration generator on the portal. Verify by description.
Patch File Load
Put the patch file that you receive from Haas Automation Inc. on a USB memory device.
IMPORTANT:  Make sure the patch file is unzipped.
The USB memory device must contain the following:
  • Your HaasKey.txt file [1]
  • Patch file [2]
Insert the USB memory device into the USB port on the Control pendant.
Go into Service Mode.
Press [EMERGENCY STOP].
Press [LIST PROGRAM].
Navigate to the USB tab.
Highlight the patch file [1].
Press [F4] System.
Select Load Patches [2] and press [ENTER].
A message "Patch File Loaded Succesfully".
Press [DIAGNOSTIC].
Navigate to the Patches tab in the Parameters tab.
Select the patch file [1].
Press [ENTER] to put a mark [2] in the box.
Press [F1] to View highlighted patch [3].
Verify that it is the correct patch. This example shows a patch to change Parameter 2.036, Y_AXIS MAX TRAVEL [1].
Press [CANCEL].
Press [F4] to Apply Patches [2].
A Patch Information prompt appears [1].
The prompt shows the patch information [2].
Press [ENTER] [3] to Apply the changes.
A Configuration Update Complete prompt appears.
Power cycle the machine.
Press [ALARMS] and navigate to the Alarm History tab.
The Alarm History page shows that the patch was applied [1].
It also shows the parameter [2] that changed. This example shows that Parameter 2.036, Y_AXIS MAX TRAVEL, changed from 2134.0 to 977.9.
Test the patch to be sure it functions correctly. For example, if you have a patch to limit the Y-Axis travel, make sure the Y Axis stops at the desired position.
Repeat Step 3 if you update the software.
The patch must be loaded and applied again if you perform a clean software install or the NGC Maincon is replaced.
 Important: You must always remove your Haas Control Key and power off the machine when you finish work on the machine.
Patch File Uninstall
Press [DIAGNOSTIC].
Press [ENTER] to remove the mark [2] on the patch [1] you wish to uninstall.
Press [F4] to Apply Patches [3].
A patch information prompt appears [1].
The prompt shows that the configuration values and factory settings for the machine will be applied. This overrides the patch that was installed.
Press [ENTER] [3] to apply the changes.
Cycle the machine power.
Press [DIAGNOSTIC].
Highlight the unchecked patch [1].
A patch information prompt appears [2].
Press [DELETE] [3].
Note: Always delete unused patches.  Never leave unapplied patches, this can cause confusion for the next service technician.
The Alarm History page shows that the patch was unapplied [1].
It also shows the parameter [2] that changed. This example shows that Parameter 2.036, Y_AXIS MAX TRAVEL, changed from 977.9 to 2134.0.
Test the machine to be sure it functions correctly. For example, if you had a patch to limit the Y-Axis travel, make sure the Y Axis movement returns to the factory limits.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
