    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
    • Storage & Handling
      Storage & Handling Shop All
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
Option Code Activation - CHC
Service Home How To Procedures Option Code Activation - CHC
Recently Updated Last updated: 06/25/2019
- Jump to Section - 1. Option Code Activation (2 steps) Back to Top
From the Haas Portal, select the Service tab [1].
Select Machine Activation Codes [2].
Select Option Codes [3].
Type the serial number into the field [4].
Select Submit [5].
Print the option codes for this machine.
Make sure the option codes match what the customer ordered. If the codes do not match, call Haas service.
Press [WRITE/ENTER].
Enable the option codes for the rest of the parameters:
All the parameter numbers for options that require unlock codes are listed below:
  1. RIGID TAP (Parameter 57:4)
  2. ENABLE ROT & SCALNG (Parameter 57:17)
  3. M19 SPINDLE ORIENT (Parameter 57:21)
  4. ENABLE MACRO (Parameter 57:22)
  5. *TSC ENABLE (Parameter 209:24)
  6. HIGH SPD MACHINING (Parameter 315:4)
  7. FOURTH AXIS (Parameter 315:14)
  8. FIFTH AXIS (Parameter 315:15)
  9. INTUITIVE PROG SYS (Parameter 315:31)
  10. ENABLE EXTENDED MEMORY (Parameter 737:2)
  11. ENABLE HARD DRIVE (Parameter 737:10)
  12. ENABLE NETWORKING (Parameter 737:11)
 * Note: For software versions before 18.07A, TSC ENABLE does not require an unlock code.
Cycle the power.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
