    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
    • 08-1760
      08-1760
      08-1760 View All
      • 08-1760
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Manual Chucks
      Manual Chucks Shop All
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
System Messages & Notifications
Service Home System Messages & Notifications
- Jump to Section - 1. System Messages & Notifications Back to Top
The 20000 alarms (20000-20017 currently) are informational messages only. These are usually generated at power up and only show in the alarm history. This information is used by our software developers for debugging purposes. They typically do not require any service action.
Event Title Description
20000 Parameter Change The control is reporting a parameter change. This is an information message only.
20001 Initialization Event The control is reporting an Initialization Event. This is an informational message only. No parts need to be replaced.
20002 Item Changed The control is reporting an Item Changed. This is an informational message only. No parts need to be replaced.
20003 SD Not Enough Space
The control is reporting a hardware failure notification event. Anytime a non critical piece of hardware fails or does not behave as expected that warning is thrown.
20004 Language Issue The control is reporting a Language Notification. This is an informational message only. No parts need to be replaced.
20005 Offsets Changed The control is reporting an Offsets Changed. This is an informational message only. No parts need to be replaced.
20006 Info Message The control is reporting an Info Message. This is an informational message only. No parts need to be replaced.
20007 Spindle Fan Failure
This is an information message. The frequency of this message will be used for debugging purposes. Inspect the spindle fan when commanded to run.
20008 YD Recovery
This message appears in the alarm history because the control detected the WYE/DELTA contactor feedback states to be incorrect but not long enough to generate alarm 4.9973. Check all the WYE / DELTA terminal connections make sure they have a tight connection. Check the transformer taps to be in the correct location. Find out if these messages occur during heavy cuts. Do not replace any parts, if these messages continue to occur generate an error report and email it to Haas Service.
20009 CNC Power Down The control is reporting a CNC Power Down. This is an informational message only. No parts need to be replaced.
20010 No Sound Card No Sound Card was detected. This is an informational message only. No parts need to be replaced.
20011 Transformer Overtemp Warning: Transformer exceeded temperature limit. This is an informational message only. No parts need to be replaced.
20012 Transformer Overheat Warning: Cabinet temperature reaching limit. This is an informational message only. No parts need to be replaced.
20013 Pallet Pool Not Run Missing Program, Pallet missing. This is an informational message only. No parts need to be replaced.
20014.0
SIO TOOL CHANGER PCB IS PRESENT
The Tool Changer PCB on I/O PCB was detected and is communicating correctly with the main I/O PCB. This is an informational message only.
20014.1
SIO TOOL CHANGER PCB IS NOT PRESENT
The Tool Changer PCB was not detected at power on. This is an informational message only.
20015 Simulated IO Event N/A
20016 Touchscreen Not Detected Touchscreen not detected. This is an informational message only. No parts need to be replaced.
20017 Security Key Event N/A
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
