    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
    • Product Image Automation
      Automation
      Automation View All
      • Automation
      • 5% off + saving on Automation
      • VF-2SS
    • 08-1760
      08-1760
      08-1760 View All
      • 08-1760
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Manual Chucks
      Manual Chucks Shop All
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Mill 3-Jaw Chuck Kits
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
NGC Software Version 100.18.000.1015 Released
Service Home Service Updates NGC Software Version 100.18.000.1015 Released
August 29, 2018 NGC software version 100.18.000.1015 has been released and is available for download from the Haas Portal.
This release is for NGC Mill, Lathe and Simulators. For a complete list of corrections refer to the release notes on the Haas Portal >Service Tab> Documents and Software > Control Software > Next Generation Control > Mill, Lathe and Simulator Software.
  • Bar feeder/ Bar pusher Improvements. (TP#27324)
  • In previous versions, it was possible to get the wrong alarm during Lathe G71 with tool nose compensation applied.   If the tool radius was larger than the arc radius, then NGC would give alarm 370 Canned cycle geometry. This has been changed and NGC will now give alarm 367 - Cutter comp interference in this circumstance. (TP# 26847)
  • In previous versions, the bar pusher air pressure did not rise back up after an optional stop.  This issue has been fixed in this version. (TP# 27375)
  • In previous versions on CL when the safe tool change location for an axis is set to inactive or when the machine powers up with the safetool change location inactive G105 may not position turret for this axis. That can cause a collision. This issue has been fixed in this version. (TP# 27490)
  • In previous versions, the CL-1 Bar pusher would use work offsets when setting the bar stop location. If you changed work offset locations, it could cause a collision with the end of bar. The Bar pusher now stores this location in Machine Coordinates instead of with a work offset. This issue has been fixed in this version. (TP# 27642)
This software release includes fixes from 100.18.000.1013:
  • In previous versions feed rate was not specified for the first feed move then instead of generating alarm 320 ( NO FEED RATE SPECIFIED ) program would skip execution of blocks. (TP#27610)
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
