    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
    • Product Image Automation
      Automation
      Automation View All
      • Automation
      • 5% off + saving on Automation
      • VF-2SS
    • 08-1760
      08-1760
      08-1760 View All
      • 08-1760
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Manual Chucks
      Manual Chucks Shop All
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Mill 3-Jaw Chuck Kits
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
NGC Software Version 100.19.000.1302 Released
Service Home Service Updates NGC Software Version 100.19.000.1302 Released
November 26, 2019 NGC Software Version 100.19.000.1302 Released
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
NGC software version 100.19.000.1302 has been released.
Corrections:
  • The APL lathe uses incorrect unload location BAR sequence.  This issue has been fixed in this version (TP# 40316).
  • LSC table operation: Y Axis Erroneous Position Behavior.  This issue has been fixed in this version (TP# 40357).
  • Vise Clamping does not work without a security key, On software version 100.19.000.1300; advancing the vise without a security key resulted in a vise alarm.  This issue has been fixed in this version (TP# 40422)
  • Grid offset being calculated incorrectly.  On software version 100.19.000.1300; the rotary autogrid miscalculates a proper grid offset.
This software also contains the fixes from software 100.19.000.1300 and .1301.
100.19.000.1301 Corrections:
  • G53 not going to correct place with G91.  This issue has been fixed in this version (TP# 40173).
100.19.000.1300 Corrections:
  • An issue has always existed such that P-Codes used with other G-Codes during dwelling canned cycles would affect the dwell time of the canned cycle. This issue has been fixed in this version (TP# 8580).
  • Distance To Go screen shows wrong value in canned cycle. This issue has been fixed in this version (TP# 20273).
  • Chamfer pauses with M23 in a G76 thread cycle.  This issue has been fixed in this version (TP# 30433).
  • G150 Making incorrect shape with arc entry.  This issue has been fixed in this version (TP# 33934).
  • APL, Erroneous alarm 12.9126 SS (2ND SPINDLE) SPINDLE CHUCK CLAMPED is generated.  This issue has been fixed in this version (TP# 35674).
  • TCPC program on a UMC-750SS can cause 549 alarm.  This issue has been fixed in this version (TP#36404).
  • Alarm 9996 MORE THAN ONE SPINDLE IS TURNING M135 is not used to turn off Live Tool.  This issue has been fixed in this version (TP# 36892).
  • Erroneous 981 PALLET POOL LIFTER ARM IS IN DANGER ZONE alarm on EC-400.  This issue has been fixed in this version (TP# 37996).
  • TR200Y does full 360 after software upgrade.  This issue has been fixed in this version (TP# 38106).
  • 2091 SOFTWARE ERROR alarms generated instead of 98XX alarms.  This issue has been fixed in version (TP# 38137).
  • VPS OD Profile Removal Cycles, X_PROFILE_STOCK Value out of range.  This issue has been fixed in this version (TP# 38141).
  • Finishing Sub-spindle, B axis, Erroneously Moves in G112.  This issue has been fixed in this version (TP# 38520).
  • Complete Probe Calibration cycle generates alarm 1106 OPM-40 need calibration.  This issue has been fixed in this version (TP# 38682).
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
