    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • Haas-Tooling-Home-TEST
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
NGC Software Version 100.20.000.1110 Released
Service Home Service Updates NGC Software Version 100.20.000.1110 Released
October 02, 2020 NGC Software Version 100.20.000.1110 Released
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
NGC software version 100.20.000.1110 has been released.
100.20.000.1110
  • Fixed Angle Vector Jogging - Introduced a Plane tab to non-GM Mills/Lathes for use in Plane Jogging XYZ axes simultaneously along a rotated XYZ coordinate system. (TP# 32410)
  • Limit RPM per Tool - For mill only: implemented new feature that allows user to specify maximum RPM for a tool. Notice that other
    limiting factors may override the specified limit. Customer can specify tool description in the same table. (TP# 43923)
  • 4.9964 alarm generated during APL sequence - On previous software versions, the first M19 or M154 commanded after the system boots up could generate an alarm 9964, Chuck Unlamped, if you main spindle chuck was unclamped.  This issue only effected new mocon lathes and has been resolved. (TP#40563)
  • APL and Robot - Support different load and unload spindle orient positions. (TP# 33300)
  • Tool cage door lock firing when jogging machine axis - An issue was introduced in software version 100.19.000.1050 such that jogging the machine would cause the tool cage to lock. This would result in rapid firing of the output when jogging with the crank. This issue has been fixed in this version. (TP# 46174)
  • Machine stalls on a G53 G0 Z0 line of code - When two consecutive rapids are commanded and Setting 335, Linear Rapids, is set to either Linear (XYZ) or Linear + Rotary, the control might be overshooting one of the linear axes and then returning it back to the commanded position. Which would cause an unnecessary stall and overall performance slowdown.  This issue has been fixed in this version. (TP# 46401)
  • Graphics run slower after software upgrade - An issue was introduced in software version 100.20.000.1100 that caused considerable lag in the displayed when a program was moving through a large number of blocks.  This was particularly noticeable when running certain programs in graphics.  This issue has been fixed in this version. (TP# 48022)
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
