      • Cep Tornası
      • Haas Çubuk Sürücüler
      • Otomatik Parça Yükleyiciler
      • Kontrol Simülatörü, Premium
      • Haas Manuel Tornalar
      • Haas Testereler
    • İmalat Makineleri
      İmalat Makineleri
      İmalat Makineleri View All
      • İmalat Makineleri
      • Lazer Kesme Makineleri
      • CNC Pres Frenleri
      • Değer Seçenek Paketleri
    • Haas Sertifikası
I/O - Tool Changer PCB - Replacement - NGC - AD0386
Servis Ana Sayfa Nasıl Prosedürü I/O - Takım değiştirici PCB - Yedek Parça - NGC - AD0386
- Bölüme Geç - Back to Top
8.3 I/O - Tool Changer PCB - Replacement
I/O - Tool Changer PCB- Replacement - NGC
AD0386
This procedure will show you how to replace the Tool changer PCB on a NGC machine.  This tool changer PCB is used on 34-349x I/O PCB that have a DC-Motor Tool changer or a bar feeder option.
This procedure applies to these kits:
  • 93-32-5502 PCB, Tool Changer - NGC
Machine Compatibility:
  • 34-349x I/O PCB
Replacement
Remove the old TC PCB from the standoffs [1] on the I/O PCB. Install the replacement TC PCB on the standoffs.
Connect cable P/N 33-0413 from J1 [2] on the TC PCB to P74 [3] on the I/O PCB.
Connect cable P/N 33-0412 from P55A [4] on the TC PCB to P55 [5] on the I/O PCB.
Connect cable P/N 33-0349 from P4 on PSUP PCB to the P55 [7] on the TC PCB.
Connect the tool changer/bar feeder cable to P58 [6].
For EC models, connect the external resistor at P57 [8].
 Note:  After installation make sure the SIO Version is 3.17 or higher and the I/O TC Version is 2.06 or higher.  If not update the firmware to the correct version.  Refer to I/O PCB Firmware - Update - NGC procedure.
  • Erişilebilirlik Beyanı
