      • Serie VR
I/O - Tool Changer PCB - Replacement - NGC - AD0386
Pagina iniziale Assistenza Procedure d’uso I/O - PCB cambio utensile - Sostituzione - NGC - AD0386
8.3 I/O - Tool Changer PCB - Replacement
I/O - Tool Changer PCB- Replacement - NGC
AD0386
This procedure will show you how to replace the Tool changer PCB on a NGC machine.  This tool changer PCB is used on 34-349x I/O PCB that have a DC-Motor Tool changer or a bar feeder option.
This procedure applies to these kits:
  • 93-32-5502 PCB, Tool Changer - NGC
Machine Compatibility:
  • 34-349x I/O PCB
Replacement
Remove the old TC PCB from the standoffs [1] on the I/O PCB. Install the replacement TC PCB on the standoffs.
Connect cable P/N 33-0413 from J1 [2] on the TC PCB to P74 [3] on the I/O PCB.
Connect cable P/N 33-0412 from P55A [4] on the TC PCB to P55 [5] on the I/O PCB.
Connect cable P/N 33-0349 from P4 on PSUP PCB to the P55 [7] on the TC PCB.
Connect the tool changer/bar feeder cable to P58 [6].
For EC models, connect the external resistor at P57 [8].
 Note:  After installation make sure the SIO Version is 3.17 or higher and the I/O TC Version is 2.06 or higher.  If not update the firmware to the correct version.  Refer to I/O PCB Firmware - Update - NGC procedure.
