      • Fresadora con cavidades
      • Torno con chuck
      • Sierra de banda
      • Fresadoras de rodilla
      • Sierra vertical
      • Sierra de inglete
    • Máquinas de bolsillo
      Máquinas de bolsillo View All
4 - Haas Surface Grinder - Installation
Haas Surface Grinder - Operator's/ Service Manual
  • 1 - Haas Surface Grinder - Introduction
  • 4 - Haas Surface Grinder - Installation
  • 4.1 Instalación
4.1 Instalación
*ESTE MANUAL ESTÁ EN CONSTRUCCIÓN*
HSG - Instalación
AD0XXX
lifting locations
shipping bracket removal
Rust inhibitor removal
oil pump fill for axis lubrication
siemens control box mounting
level
levelling 2
hydraulic tank install
Paper Filter Install
positioning
hose connections
wiring
Vacuum install
Geometry verification and adjustment
test grind
dresser alignment adjustment
final test grind check
  • Terminos y Condiciones
